seafoam in an 08 si--14,000 miles??
yay or nay?---------
just a normally driven si......always with 91 grade.....should i as a matter of routine run a can of seafoam through a full tank of gas every so often or not??
thnx all
thnx all
i have done it to mine once. i did it at 35,000 miles. i only used a half a can tho. i would like to hear what ht thinks tho. i have used it on other cars in the past.
i've only ever used seafoam when my motor wasnt working right...ie it was knocking bad.
but if you do seafoam it....be sure to video tape it!
I'd like to try it....
I do have 52K on mine. But I also only use Shell V-Power or Texaco and the occasional Lucas Fuel Cleaner, along with some good M-1 oil changes and HAMP filters.
I'm sure my motor is spotless inside from the maintenance I have giving it thus far. So I probably don't need it but I can't see it hurting if you use it every so often. Maybe like ever other oil change or so.
Anyone?
Anyone?
I didn't drive much when I first bought the car, then I started driving more. I have some road trips and well as highway miles. Nah I usually change it around 5K.
My car had 23,500 on it when it became a year old. At that rate, after three years my car will have just over 70k miles on it. Thankfully, I don't drive it at the rate I used to though, so I will probably be closer to 60k after 3 years. I had 10k on my car in under 3 months from driving to meets, to my gf's college and just driving for fun...lol.
HA0589
31
Mar 5, 2014 09:09 PM
