super charger gods chim in
Old Jan 26, 2009 | 03:12 PM
romerosi's Avatar
Default super charger gods chim in
hey everyone, im running a gsr with a jackson charger on it and basically i am running threw charger belts as fast as oil changes, what belts are you guys runing, ive tryed gates and napa belts so far and both no go, after a few thousand miles the belts are missing chunks and pretty much destroyed. i am a honda tech and im pretty sure i have a good idea on belt tension, but im open to what everyone has to say
Old Jan 26, 2009 | 04:49 PM
romerosi's Avatar
Default Re: super charger gods chim in
anyone?
Old Jan 26, 2009 | 05:13 PM
digital sol's Avatar
gonna take a little while to get a response..........take a smoke break
Old Jan 26, 2009 | 05:30 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
does the charger spin freely?
(I dont know crap about s/c's but if its binding up that could eat belts)
Old Jan 26, 2009 | 05:50 PM
Schister66's Avatar
Man U FTW
I would first check if everything is tight to spec. If the tensioner pulley for the JRSC is loose, it may cause the belt to bend slightly for or aft therefore causing excessive wear on the edges. After that, i would check into the lubrication of the supercharger. Improper lubrication would increase the turning friction and eat belts faster. Those are the first things that come to mind, but i've never run an SC setup on my GSR. Good luck
Old Jan 26, 2009 | 06:02 PM
Jaker's Avatar
It's there in the supercharger thread for the searching. You'll need to carefuly check your pulley alignment. There also a chance the tensionner pulleys are packing it in.
Old Jan 27, 2009 | 04:29 PM
romerosi's Avatar
ok thanks everyone, the charger spins freely, im gonna double check pulley alignment but it doesnt throw the belts just wears them out fast, so i dont think thats the issue but i will double check, anyone recomend any belts, or size,
Old Jan 27, 2009 | 06:43 PM
https://honda-tech.com/forums/showth...14810&page=297
gatorback poly v belts
Old Jan 27, 2009 | 09:25 PM
rmcdaniels's Avatar
Also check the upper alternator mount alignment. Did you install the two shim washers that came with the kit to move the upper alternator mount? There's actually an alignment problem with the lower mount casting, but you can't change that so they included shim washers in the later kits for the upper mount. Here's a post I made on how to do it with some pics:
https://honda-tech.com/forums/showth...b#post20789129
You can also get some custom pulleys for your kit, the ones that come with it are not designed well IMO. Here's a post with pics from a guy that had a set made:
https://honda-tech.com/forums/showpo...ostcount=10478
With a shimmed upper mount and a good set of pulleys mine was rock solid at the track and my belts lasted a while.
You will wear belts more quickly with the blower, so expect to change them more often, and every few months is not unheard of.
Old Jan 27, 2009 | 10:29 PM
HYREV2NR's Avatar
^^^^^^^^This has to be one of the best SC threads anywhere for Hondas!
Old Jan 31, 2009 | 12:42 PM
romerosi's Avatar
thanks alot, i am def gonna check the alignment
Old Feb 2, 2009 | 09:08 AM
HYREV2NR's Avatar
Saw your sig., couldn't agree more.
GsrVtec
Sep 24, 2006 10:02 PM
SamC
Jul 1, 2004 10:32 AM
siis2fast
Apr 21, 2003 05:04 AM
