Base Fuel pressure question ???
Old Jan 28, 2009 | 10:46 PM
jdm-gsr's Avatar
Default Base Fuel pressure question ???
fuelsetup is :
after market fuel rail
precision 1000s
sard fpr
walboro 255 intank
this is on a gt35r b18c sleeved built
what base fuel pressure should i set, currently is at 40 psi
i have a inline walboro 255 also if the need be i can put that as well
dont have a dyno but planning to run around 26 psi of boost on 100 octane
Old Jan 29, 2009 | 05:21 AM
96 GSR-T's Avatar
Default Re: Base Fuel pressure question ???
so your going to street tune to 26psi? That should be interesting.....
I run a base of 50psi, seems to work well.
Old Jan 29, 2009 | 07:40 AM
boostedcivicsir's Avatar
Mr. Badwrench
same here.
Old Jan 29, 2009 | 08:05 AM
tractionwhat's Avatar
id say a safe place to start 45-50 then work it out as you tune
i usually set mine at 45 to start and see where i'm at
Old Feb 1, 2009 | 11:14 PM
jdm-gsr's Avatar
how else do you propose i should tune a car with out a dyno/rolling road ?????
Old Feb 2, 2009 | 03:32 AM
blinx9900's Avatar
He'll be fine, there are some people that can street tune as good as some can dyno tune, as long as he can monitor a/f and has a good EMS i see no problem, my car was street tuned and runs great, the tuner in my area only does street tunes and a lot of evo guys go there, they all say the car still drives like stock, gets great mileage and is fast as other evo's that are dyno tuned with similar mods.
The tuner is the key, the dyno is only a tool. Some of the fastest cars are NOT dyno tuned, they are actually tuned at the drag strip which is street tuning in a controlled environment
Old Feb 2, 2009 | 06:13 AM
96 GSR-T's Avatar
a track, dont know how much power you plan on making but anything over 500whp is going to roast tires which doesnt give you a very good log of whats going on, not to mention flying by other people at 130mph.
Old Feb 2, 2009 | 07:14 AM
SOHC_MShue's Avatar
The track is different from the street. You can see changes in the tune affect mph to tune off of. On the street you are just going by how fast it feels on the butt dyno. Without being able to see measurable torque changes I dont see how you can properly tune ignition timing...and no tuning it to the point of knock isn't the propper way either. Not to mention street tuning can be very dangerous.
Old Feb 2, 2009 | 09:51 AM
jdm-gsr's Avatar
too bad i dont have a dyno here nor a drag strip ... but i do have i few abandoned roads here... so i cant help that .... ill have to do what i can with what ive got ...... been doing it uptill now ....
90civicgsr
Nov 6, 2007 10:28 AM
Wicked_CRX
Jul 12, 2003 12:33 AM
toooslow
Jun 13, 2003 04:06 PM
TurbothisLS
Jan 2, 2003 03:43 PM
95integrags-r
May 8, 2002 02:25 PM
