What type of injectors are these?
My apologies in advance if this is in the wrong section.
These injectors came on the car when i bought it. im doing a rebuild and need to know what kind/type of injectors are these. Also each injector had a resistor wired into it?
Every Injector reads INP - 018, on the other side it reads MDL 450 .
Any help would be appreciated.
They are peak n hold type injectors which require a resistor box to run correctly and not do damage to your injector driver in your ecu.
http://www.hondata.com/techlowohminjectors.html
edit: already got your answer, slow reply by me.
750cc will get you 450whp safely, meaning about 80-90% duty cycle. With all current EMS's, you can also run 1k's w/o any negative issues. Bosch makes saturated 1k's that someone proved show gains just by better fuel atomization alone, but aren't as cheap as peak/hold 1k's.
