CAT removal HELP!
Old Jan 23, 2009 | 09:24 PM
t0kyoStatus's Avatar
Icon2 CAT removal HELP!
My CAT is clogged. It is disconnected at the header. Now Im just trying to get the bolts off the other side of the CAT. They are rusted on good. So I got a grinder and cut the heads of the bolts off. Didnt touch the nuts because I didnt want to damage the exhaust piping Im still gonna use. The heads of the bolts are cut off. I cut into the CAT good you can see the outline of the bolt in the metal. I put PB Blaster and hit the end of the CAT with a big hammer and wont come off. Even tried a chisle wedge in the 3 corners no luck. Any ideas?? Maybe get it red hot with a torch??
-Thanks
Old Jan 23, 2009 | 09:29 PM
93egSLEEPER's Avatar
Default Re: CAT removal HELP!
-Thanks
hold on what are you trying to do? im confused... take bolts out of the cat or exhaust?
Old Jan 23, 2009 | 09:31 PM
take the bolts off the cat where there are 3. I got the side where the 2 bolts are with springs. STUCK
Old Jan 23, 2009 | 09:33 PM
you put penetrating oil and all that on there?
i had a similar problem but just lubed em up good for a while and went at it hard and they broke loose.
Old Jan 23, 2009 | 09:41 PM
yup. will spray more.
Old Jan 23, 2009 | 09:43 PM
FYI prob not the best idea to torch anything with penetrating oil all over it. haha
Old Jan 23, 2009 | 10:41 PM
j0keefe21's Avatar
i had same problem. i unhooked my hangers on my exhaust and wiggled my exhaust around untill the cat was out the side of my car and went at it with a hack saw since i didnt have a grinder... you can try it that way if you want.
fw190bvi
Apr 25, 2005 04:09 PM
Cyber ITR
Dec 17, 2003 07:43 PM
dip-set
Nov 21, 2003 08:04 AM
JeremyL
Dec 16, 2002 04:41 PM
