Wide open throttle issues
Old Jan 23, 2009 | 07:32 PM
Jap_Spec_Imports's Avatar
Default Wide open throttle issues
When I start up my car it idles great, however when I open the throttle body it starts surging. The MAP and TPS are on and working, can anyone diagnose this issue?
Old Jan 23, 2009 | 07:33 PM
Unseen Racer's Avatar
Default Re: Wide open throttle issues
how is your IACV?
Old Jan 23, 2009 | 07:41 PM
SOHC_4dr's Avatar
did you test the MAP and TPS with a voltmeter to make sure they are working correctly? you could have a leak somewhere
Working good. No issues, when I open the TB it sort of Bogs and begins to die. Any ideas?
Old Jan 23, 2009 | 07:49 PM
SOHC_4dr's Avatar
hmmm. i think your ignition timing may be off. have you messed with the distributor any?
93egSLEEPER's Avatar
have you done any work to the car recently modifying anything or taking anthing off or loose?
Old Jan 24, 2009 | 09:16 AM
Not as of yet.
Old Jan 24, 2009 | 09:17 AM
Nope
aasaa666
Jun 29, 2008 08:13 PM
SpoonEk253
Sep 26, 2005 11:37 AM
irev210
Oct 19, 2004 04:14 PM
