turbo take a dump?
its not making full boost. It makes like 5-7 psi only now, i didnt find any boost leaks or popped off charge piping. the shafts have alittle play but not much on comp and ex side. it doesnt smoke or anything. Any ideas would be appreciated guys.
check your spring on the wastegate>>???
1.You should try making a boost leak tester, I made one for a couple bucks...sounds like you may have a tiny leak...
2.check your wastegate vacum sources, and make sure its opening properly
3.also are you running a boost controller?
turbo95eg6
Jun 12, 2005 12:15 PM
