Im new to civics
Old Jan 22, 2009 | 08:59 PM
jdmdc2boi12's Avatar
Default Im new to civics
Hey guys i just bought my little bros 95 civic for $400.. he decided jsut to sell the car because it over heats and just failed the smog this smog... the shop wher he got it smog said that the radiator fan might be the problem thats why the car overheats at high rpm... now, i decided to just get a same motor with less mileage sncie his car has over 18xxxx and thers oil leaks everywher... now my question is, is ther any write up or anything that shows u how to remove the motor?.. i know some basic some but never done a swap before... by the way thnx for all the help u guys really appreciate it.. oh yea this is my other project beside the civic... heres some pics.. thanks again!!!!!
and here is my dc
the video
http://s249.photobucket.com/albums/g...t=MOV02270.flv
Old Jan 22, 2009 | 09:05 PM
92hatch!'s Avatar
Default Re: Im new to civics
https://honda-tech.com/forums/showth...+do+engine+how
92hatch!'s Avatar
read that^^ it should help
Old Jan 22, 2009 | 09:25 PM
iamthefollower's Avatar
that DC is really clean dude, I love the rota's.. hope you get the swap done ok..
Old Jan 22, 2009 | 09:59 PM
thx but not enough info
thx
Old Jan 22, 2009 | 10:04 PM
civicpath's Avatar
that teg is super dump...what kind of suspension kit did you go with?
Old Jan 23, 2009 | 11:32 AM
bump bout any write up how to remove engine... or any suggestion why the car over heats.. thx
Old Jan 23, 2009 | 11:37 AM
EJ8freek's Avatar
That DC2 is seriously dumped. Some bad footage.
Old Jan 23, 2009 | 01:52 PM
no answers>?
Old Jan 23, 2009 | 02:55 PM
LwdJdmR's Avatar
First what anyone should do is search . . . .
just like i did, for you!
https://honda-tech.com/forums/hybrid-engine-swaps-18/faq-detailed-b-series-swap-into-5th-gen-civic-how-check-out-help-everyone-else-too-131949/
Old Jan 23, 2009 | 04:29 PM
NotAdelslow's Avatar
it could be the thermostat...could be the head gasket. you can check the both of those and maybe and hopefully all you need to do is replace either of those. happened to mine and it was the head gasket. check to see if the head is warped too if it comes to that. another thing that can be wrong is the water pump....so thats all i know
Old Jan 23, 2009 | 05:06 PM
or your radiator could be bad now, but it could be a matter of any problems, as one has stated already.. could be the water pump, head gasket(check for water in the oil), thermostat, or as I stated the radiator.. my car overheated for a while, and I changed the thermostat and all.. it ended up being my radiator.. take your thermostat and put it in some boiling water and see if it opens or not.. if it doesn't it's bad...
Old Jan 23, 2009 | 08:40 PM
thx guys
kenlrw39
21
Sep 26, 2008 07:32 AM
hybridfever
Jul 22, 2007 06:52 PM
yz125rider21
Jun 29, 2006 04:44 PM
kinvid22
18
Oct 23, 2003 12:59 PM
EclipticX
Sep 29, 2003 05:35 AM
