help! obd2a to obd2b harness conversion lsvtec distributor wiring problem?
Old Jan 22, 2009 | 04:32 PM
billmongold's Avatar
Default help! obd2a to obd2b harness conversion lsvtec distributor wiring problem?
im doing an ls-vtec conversion and im using an obd2b harness and a p72 head. i mocked the harness up to the ls motor and looked at the connectors. i noticed that the distributor has a male connector and the obd2b harness also has a male connector. the obd2a harness had 8 wires on a female connector and the obd2b harness has 9 wires in a male connector. how can i adapt it or wire it so i dont hafta buy a 99 si distributor? engine is a 96 ls and the car is a 96 civic hatch. it has a p75 ecu for the ls motor and i have a p72 ecu for it till it gets tuned. anyone have these problems before with this harness?
wiring diagrams/schematics welcome.
Old Jan 22, 2009 | 08:45 PM
Default Re: help! obd2a to obd2b harness conversion lsvtec distributor wiring problem?
nobody? come onnnnn
Old Jan 16, 2020 | 08:15 PM
Averageswapcris's Avatar
Well something is wrong you should have 9 wires for both, I just rewired the b4 CR-V distributor clip into b20b regular clip so it's possible
Old Jan 17, 2020 | 04:02 AM
muellersfan's Avatar
11 year old thread.
Old Jan 17, 2020 | 06:50 PM
tony_2018's Avatar
Fish Twig
something is def wrong this yr...
Evan214
Jul 6, 2020 09:32 AM
hondakook
Apr 5, 2009 06:37 AM
4dek
Jul 6, 2008 06:13 PM
RotiEatter
Jan 11, 2005 11:46 AM
