How to lengthen Transmission Gear ratios?
Old Jan 22, 2009 | 09:09 AM
Matt55's Avatar
Default How to lengthen Transmission Gear ratios?
I am thinking about boosting a 00 civic si. But im told that it would be a real neck snapper since the gears are so short. Is there anyway to lengthen these gears?
Old Jan 22, 2009 | 09:14 AM
kp's Avatar
kp
Default Re: How to lengthen Transmission Gear ratios?
I'm no transmission tech, but I'd say to research a different transmission, or do some real homework and find out if you can swap in a taller final drive/different gear set.
Old Jan 22, 2009 | 09:16 AM
Ser1N's Avatar
I think the LS tranny has the longest gearing? for b series
Old Jan 22, 2009 | 09:18 AM
Matt55's Avatar
Yea i really dont wanna swap the tranny because i lik the si's ill look into the gear set though. I just heard around that you can lengthen the gears but they didnt know how
Old Jan 22, 2009 | 09:21 AM
Ser1N's Avatar
You swap gears from the LS tranny to the SI tranny =x
Old Jan 22, 2009 | 09:29 AM
kp's Avatar
kp
It's not just as easy as "lengthening" the gears, theres some serious work involved regardless of what route you decide to take.
Old Jan 22, 2009 | 09:35 AM
Matt55's Avatar
Do u know of a site where i could find out more about it?
Old Jan 22, 2009 | 09:39 AM
turbojdmhatch's Avatar
honda-tech.com
jimmy o.'s Avatar
Just get an LS trans has longer gears than B16 and they are cheap
Old Jan 22, 2009 | 09:40 AM
Mikes2000civicsi's Avatar
well you press start,go to tune car,press r2 to get to transmission,and then you can mess with any gear,even the final drive.(forza 2 Motorsport)
On a realistic note,just swap out the transmission for either a gsr or ls
Old Jan 22, 2009 | 09:50 AM
Allurian's Avatar
like another has said your cheapest most beneficial route is to purchase a GSR trans. It would be cheaper than increasing the final drive in your b16 tranny and better for boost
Old Jan 22, 2009 | 09:51 AM
Matt55's Avatar
thanks
Old Jan 22, 2009 | 10:11 AM
badboyr66's Avatar
If it is for the track... a larger wheel size will increase your overall final drive. If not get ready to spend some money on intenrals
Old Jan 22, 2009 | 10:17 AM
TwoKSiR's Avatar
badboyr66's Avatar
Back on topic guys...don't go get your thread locked. You need answers not arguments... lets work on it.
Old Jan 22, 2009 | 10:18 AM
TwoKSiR's Avatar
But seriously. Leave your Si tranny in there. I have lots of friend's boosting on Si tranny's on all different levels of setups.
Old Jan 22, 2009 | 10:20 AM
Matt55's Avatar
do they complain about the short gears?
badboyr66's Avatar
Yeah and one thing to point out is if you go get a GSR tranny... they are a little longer after 1st gear. The SI tranny is worth plenty and could prob be swapped with someone looking for something shorter. I myself chose an SI tranny over my GSR. But then again I am NA
But like we were saying, lots of people use a SI tranny. Those boosting look for smaller more reactive turbos. Something to think about
Old Jan 22, 2009 | 10:25 AM
TwoKSiR's Avatar
Not at all. The tranny's pretty much eliminate turbo lag. There cars spool so fast. What kit are you going with or what size turbo?
CrxFihn
Apr 2, 2013 03:08 PM
MurkyRiversEK
Transmission & Drivetrain
19
Aug 14, 2012 12:45 PM
JDMkidGSR
Jul 2, 2004 05:46 AM
One8Hatch
Dec 18, 2001 09:08 PM
