Engine swap... Assembling correct parts.
Old Jan 22, 2009 | 08:58 AM
civics4lyfe's Avatar
Default Engine swap... Assembling correct parts.
i was looking at buying a b16a from a 93 teg XSi from a local seller. But then i would need to find a transmission to go with it for a swap into a 94 civic dx hatch. What should i be looking for? lsd? hydro? cable? Im not looking for best torque or horsepower, itll merely just be to get the b16 in for show purposes, and have her running reliably as a dd. Cheaper would be better.
will a 93 teg half shaft and axles work?
what shifter linkage am i lookin for? all i found was the hasport b series linkage for 92-95 civics which was rather pricey.
Old Jan 22, 2009 | 09:05 AM
sp00ledbseries's Avatar
Default Re: Engine swap... Assembling correct parts.
as far as the tranny goes you can use any b series tranny. but i would go with a hydro ls or gsr. as for your shift linkage goes you need a eg b series.
Old Jan 22, 2009 | 09:10 AM
kp's Avatar
kp
Hydro LS would completely defeat the high end power of the B16. It would be like driving a slug. You can use any B series tranny but since your EG has a hydraulic actuated clutch, you should buy a hydraulic tranny, possibly a GSR/ITR. And you'll need a shift linkage from a 94-01 Integra, not a "eg b series" linkage (whatever that means).
The 93 teg axles/half-shaft will work, but only if your using a cable transmission. If your using a hydro transmission, you'll need axles/half-shaft from a 94-01 teg. ("hydro axles" with hydro tranny, and "cable axles" with cable tranny.)
Old Jan 22, 2009 | 09:35 AM
meant to say dc instead of eg im tired as hell
Old Jan 22, 2009 | 09:46 AM
so pretty much i need a 92-93 cable tranny with half shaft and axles and an eg b series linkage, or
94-01 hydro (gsr) tranny with 94-01 half shaft and axles and 94-01 linkage?
hah its my first swap. i have a 95 ex coupe, but ive never done anything major just as an engine swap to her.
Old Jan 22, 2009 | 09:48 AM
http://hmotorsonline.com/shop/sc2000...age&item=30003
so if i would order that... all i need is the b series motor mounts for an eg civic?
Old Jan 22, 2009 | 09:49 AM
Originally Posted by civics4lyfe
so pretty much i need a 92-93 cable tranny with half haft and axles and an eg b series linkage, or
you need a 94-01 integra shift linkage either way but you got the other stuff right my bad for confusing you
Old Jan 22, 2009 | 09:52 AM
so the clutch being hydraulic or not depends on the transmission?
Old Jan 22, 2009 | 10:02 AM
ek4_b16a's Avatar
the tranny you have in your car right now is a hydro tranny. you will need everything from a hydro swap to make it work.
halfshaft from hydro swap
b-series motor mounts
dc teg shift linkage
and to answer your question, the tranny in your coupe is hydro, and yes, the cable tranny won't work in your car, unless you buy the conversion kit for it. but you're best off getting yourself a complete obd1 swap. easier for you
Old Jan 22, 2009 | 10:23 AM
teamworxek9's Avatar
If you're asking simple questions like this how are you gong to do the wiring? Have you done any research on the swap at all? Dont forget to figure out what your going to do for your dizzy (distributor,) ecu. Good luck.
Old Jan 22, 2009 | 10:27 AM
If the car comes with a cable tranny just sell it ot trade it for a hydro tranny. But as already mentioned you could get a conversion kit. That would be the cheapest wat to go.
Old Jan 22, 2009 | 10:31 AM
ek4_b16a's Avatar
but if you use the cable tranny, you will need the axles from the cable trans too.
Old Jan 22, 2009 | 11:03 AM
my buddy has a honda shop and will be helping me do the swap. but i want to know wtf im doing so im not just sittin there watchin him, and so that i can do it myself next time.
any writeups on what to do with the dizzy?
if the hatch is a shell i would get from a junkyard, how would i be able to tell if the transmission it came with was cable or hydro?
NukeEm
Feb 16, 2014 01:39 PM
-=ZAK=-
20
Oct 22, 2008 12:47 PM
91civicsikid
Jun 13, 2008 05:14 AM
stemiched
Northeast (Sales)
May 23, 2007 04:17 AM
keepitngga1
Oct 10, 2006 02:28 PM
