Eagle rods d16y8 feels slugglish low rpm
Old Jan 21, 2009 | 08:53 AM
central_driver's Avatar
Default Eagle rods d16y8 feels slugglish low rpm
I did a vitara low compression set up with acl bearings and eagle rods and all the clearances were fine. It drives perfect anything under about 3,500rpm but anything under that it seems sluggish like it doesn't wanna move smoothly. I thought maybe because theeavle rods r heavyer? It drives smooth flooring it and all high rpm just daily driving low rpm it's kinda laggly
Old Jan 21, 2009 | 08:58 AM
lluks_844's Avatar
Default Re: Eagle rods d16y8 feels slugglish low rpm
i think you answered your own question. low compression pistons, heavier rods. If it is that bad thanmaybe your timing is off.
Former User's Avatar
Have you checked both the mechanical and ignition timing?
Old Jan 21, 2009 | 09:13 AM
Schister66's Avatar
Man U FTW
Is this setup tuned?? The lower compression will effect the lower rpm drivability and WILL feel sluggish. The lower the compression, the less response off-boost.
Old Jan 21, 2009 | 11:04 AM
it's bone stock from the outside. I'm going in for smog this week. Stock ecu everything. Everyone was top dead center and I hear no valves hitting or valve lash. It just feels like you have 100hp than for half a second it goes to like 90hp than back to 100hp. Just trying to explain what I mean. When I give it gas and it's over 3500rpm it's smooth all to redline. Too smooth actually compared to my old 155,000mile motor. This is overbored and all brand new
Old Jan 21, 2009 | 12:32 PM
hondadriver's Avatar
I'm gonna say its your mechanical timing. When i did a mini-me on my d16y7, I thought I had everything aligned properly too. But when i took it for a ride it was terrible under 3k, no matter how fast i tried to accelerate, it was the same way your describing your problem. And it was normal over 3k. So i put my pistons at TDC, and my cam gear was off one tooth. So that may be ur problem.
Old Jan 21, 2009 | 01:00 PM
EX-T's Avatar
Yeah, I have the same exact setup in my Y8 and it's not sluggish at all. It's going to be your timing dude. Check that out and then get back to us....
Old Jan 21, 2009 | 09:03 PM
i checked timing. its perfect. everything is top dead center. i replaced the spark plugs with extra one si had layign around. and i reset the ecu. nothing changed....
Old Jan 21, 2009 | 09:36 PM
Adam_b16a's Avatar
So its not tuned? Are you planning on running a turbo?
Old Jan 21, 2009 | 10:24 PM
yea its not tuned. thats why my guess was the low compression and to much of fuel is making it feel like that. its annoying as hell but the car runs great other than that...
Old Jan 21, 2009 | 11:08 PM
Adam_b16a's Avatar
Why are you driving and bringing a built engine up redline without it being tuned first?
Old Jan 21, 2009 | 11:16 PM
brand new motor. breaking it in hard because thats what this car has to get used to. but my question is does anyone have this problem. Ill try and get a video. I mean the car is perfect no weird noise. timing is perfect. i no the compression went from 9.6.1 to 8.5.1 and its probably not burning all the gas that goes into the combustion chamber. any tips on anything i can use to help? I pulled the spark plugs and they are look real white.
Old Jan 21, 2009 | 11:19 PM
http://www.youtube.com/watch?v=Ued7JJaJR-0 fast forward to 6:00 on the video unless u wanna watch all of it.
this was the second day it ran. it was still doing that but its not noticeable on video. its not something you notice but something u feel. i thought it was just breaking in since its all new but it aint going away
and btw its all stock right now. stock headers, stock everything but with a short ram intake. power steering etc... no check engine lights.
4.8t
May 4, 2011 10:10 PM
Leland
Oct 1, 2009 01:33 PM
Superdragr45
11
Dec 20, 2004 01:37 PM
dirtyturtle
15
Jun 30, 2004 10:19 AM
advanracing62
Feb 2, 2003 08:37 AM
