How much did your motor swap cost?
Old Jan 20, 2009 | 10:23 PM
808EK4's Avatar
Default How much did your motor swap cost?
Hey guys, anyone still remember how much their motor swapped costed? If they did it themselves or by a shop and how long did it take them. Also, please include your engine and chassis. I'm just trying to get some figures so if I should try and tackle the job myself or leave it to the professionals to do all the dirty work. I'm deciding on get a B-series engine in my 96 civic hatchback.
Old Jan 21, 2009 | 03:33 AM
scott3193's Avatar
Default Re: How much did your motor swap cost?
4800$ cad
Old Jan 21, 2009 | 04:36 AM
slugo10's Avatar
I did it myself in 2 days. 96 EK hatchback with JDM b18C swap. I think i have about $4000-4200 after all said and done with new belts motor mounts water pump and few odds and ends.
Old Jan 21, 2009 | 04:57 AM
90Rexx's Avatar
mine will cost me total of about $2400. thats a B18C1 in a 97 civic hatch. the engine tranny ecu and axles cost me 1500 then the swap parts like linkage harness mounts clutch set and other odds and ends i estimate slihgtly under a thousand... i also purchased everything used... im doing mine currently... i figure ill be just under 2500 said and done.
Old Jan 21, 2009 | 05:14 AM
JKov240's Avatar
I did mine over a weekend with my brother and dad helping.
And I lucked out and got my B18C1 for $800, but ended up rebuilding it with forged pistons/rods and "overhauling" the motor for around $3K.
Old Jan 21, 2009 | 05:32 AM
namewasdallas's Avatar
jdm b16a2 into 98 civic ex had a shop do it, Came to 3800 or so, motor from hmotorsonline, swap by synapsemotor sports, left them my car for a week, everything done perfect.
Old Jan 21, 2009 | 05:39 AM
mage182's Avatar
Going into a 1993 Civic Si:
97 LS Engine - $200
00 LS Tranny - $300
Timing belt, water pump, belts, plugs, wires, filters, fluids - $250
ES Shifter bushings for LS - $30
Exhaust bits to make it work - $40
2 new axles - $120
2 ball joints - $60
Old Jan 21, 2009 | 06:00 AM
redracerk20's Avatar
dont swap a ***got B series.........just boost your D, on stock internals you can easily boost 8psi and spank all the b16 you want lol
Old Jan 21, 2009 | 06:06 AM
Jimster480's Avatar
Ya don't swap ur d. It isn't worth it. Just boost it and it will spank gsr's and b16s all day for half the price.
Old Jan 21, 2009 | 06:17 AM
kp's Avatar
kp
Of course this topic was going smoothly until the last two posts. ^^^
But to actually answer your question, I'm swapping a B16a into my 94 hatch and I figure by the time I'm done it'll have costed roughly $1500. I'll be swapping it myself over (hopefully) a weekend.
Motor/tranny - $550 (already bought dirt cheap off a friend)
Misc. Linkage, Mounts - $250 (all scrap yard finds)
ECU - $250-$350 (stock ECU or possibly a chipped P28)
New gaskets, rings, seals - $350 (New valve seals, HG, P. Rings, various gaskets)
Old Jan 21, 2009 | 08:50 AM
94EG8's Avatar
Seagull Management
OBD1 JDM D15B Vtec swap, complete engine, reused existing tranny, engine was $683CDN after tax and shipping. Timing belt and water pump was another $120 or so (I used aftermarket, although OEM is the way to go, I was pretty much flat broke at the time and needed my car to start a new job). Installed the engine myself. Final price was around $850
Old Jan 21, 2009 | 09:17 AM
Malfa's Avatar
about $4000
2000 civic auto d series
to manual b series
Old Jan 21, 2009 | 09:33 AM
boost it............
Old Jan 21, 2009 | 09:37 AM
Arcitekt's Avatar
MOB Mentality
Shouldnt be too much . network ! network ! network! youd be surprised how many grease monkeys are out there who can swap your b-series motor into your eg with ECU ,linkage if necessary , tranny "depending on what ratios preference and axles etc. for cheap. a good friend of mine swapped a b18c motor on my EM1 for $800. and ive had flawless results. again depends on who you know.
Old Jan 21, 2009 | 09:43 AM
Vindicator9000's Avatar
318 Curves, 11 miles
2000 Civic. Swapped in a USDM B18C1 with a B16 tranny. Did it myself.
70K mile B18C1 with Si tranny, plus mounts/P72 ECU/bad axles: $2080 picked up from an H-T member.
Exedy OEM clutch kit: $90 shipped from Ebay
Resurfaced flywheel: $55 from a local machine shop.
Remanufactured axles: $100 from orly's with core return
Fluids/oil filter: $40
CRV AC Bracket: $75-ish from Majestic Honda
Tranny seals: $15 from Majestic Honda
Assorted vacuum lines/heatshrink/wireloom/solder/butt connectors/: $20
Total: $2485
Swapthread in my sig.
Old Jan 21, 2009 | 09:51 AM
MurdersV8s's Avatar
93 eh3 with jdm b18c. I already had a b16 so all I needed was a b18c longblock from hmo. I payed $2000 including shipping. Me and my buddy did the work. All in I paid about $2300 including basic maintence parts such as water pump, timing belt and a few others. Then I sold the bare b16 for $350 so a grand total of $1950. You can't beat that.
Old Jan 21, 2009 | 09:57 AM
Mashimaro's Avatar
First swap was a JDM '94 GSR into an EJ1 (complete motor, installed by my local shop with new clutch flywheel, water pump, timing belt, fluids, etc..) was $4000CAD about 4 years ago.
Second swap was a JDM '98 Spec ITR into an EG hatch (re-used clutch/flywheel, but paid for new timing belt, water pump, etc) $6000 approx CAD about 3 years ago. (the shop bought back my GSR motor after a year of use for $3500 cuz another customer wanted one badly, so that's when i went ITR).
Shop did the swap in 1 day (out with the D, in ith the B).
ps - "costed" is not a word
wolf07
May 25, 2005 08:24 AM
Addijhaq
Apr 24, 2005 07:27 PM
2000Accord5sp
12
May 10, 2002 09:05 AM
NIM
Mar 17, 2002 12:44 PM
