VAFC for non-vtec??
Old Aug 6, 2002 | 07:48 PM
RedDawg's Avatar
Default VAFC for non-vtec??
I got a great deal on a VAFC but i have an LS integra, i can use it the same as an SAFC except that the vtec wire won't be installed right?? It should function the same right?? and where have you guys mounted yours??
Old Aug 6, 2002 | 07:55 PM
JaeOne3345's Avatar
Default Re: VAFC for non-vtec?? (RedDawg)
yup itll work fine. i actually think its good to have a vafc period incase u ever go vtec. for people with non vtec ecu's..such as many woth z6's in EFs..u can use the afc to power vtec .
Old Aug 6, 2002 | 08:49 PM
shermanyang's Avatar
it functions just fine, except that you may need to adjust the fuel/air curves a little different. other than that, it works fine. i had my vtec wire from the VAFC hooked up to a little green light on my dash and when it would kick in, that little light would light up. i just thought that was kinda neat.
Old Aug 6, 2002 | 11:59 PM
RedDawg's Avatar
Default Re: VAFC for non-vtec?? (shermanyang)
ok, thanks guys
Old Aug 7, 2002 | 12:19 AM
Norcalstoppy's Avatar
I think you could just set the vtec crossover higher than your redline, so that vafc won't start dumping extra fuel. That way you only have to tune 1 constant curve.
just my $0.02!
Jay Kim
Old Aug 7, 2002 | 02:12 AM
kinesistech's Avatar
I think its a good idea to have it. You can use it as a NOS rpm switch too.
Traser
Nov 17, 2006 11:30 AM
2fknlo
Feb 2, 2003 08:15 PM
ludespeeder
Jun 20, 2002 07:08 AM
BoroDB8
Apr 25, 2002 05:20 AM
EleanoR
Apr 17, 2002 06:06 PM
