obd2 port not working
Old Jan 20, 2009 | 06:38 AM
ekb20's Avatar
Icon2 obd2 port not working
i have a 96 civic cx. i tried to hook up obd2 scaner to read codes and it says...."unable to connect". i really havent started to look at this problem. where should i start? can it be a fuse? the green plug on the wiring to the ecu is pluged. any input on this problem is deeply appreciated. thank you my h-t family.
Old Jan 20, 2009 | 06:53 AM
slimjimming6688's Avatar
Default Re: obd2 port not working
i know you chould get power from one of the pins, i think 16 is ground and one of them ahould be power, cant remember, it may be that the wire connector is a lil bent and is not connecting to your scanner
Old Jan 20, 2009 | 08:27 AM
iliv2xlr8's Avatar
Time to convert to OBD1 for that chipped ECU....
www.phearable.net
Old Jan 20, 2009 | 08:29 AM
ekb20's Avatar
lol thanx....but i still need to pass inspection
Old Jan 20, 2009 | 08:31 AM
Unseen Racer's Avatar
look inside to make sure that a pin hasnt broken off.
Old Jan 20, 2009 | 08:44 AM
JShull's Avatar
Check your fuses as well.
SCsol
Oct 7, 2005 05:35 AM
STG3PWR
Dec 13, 2004 12:15 PM
95excoupe
Nov 17, 2004 11:27 AM
CivicFerioSiR
Aug 25, 2003 08:22 AM
ozzyman
Sep 4, 2002 07:57 PM
