Honda S2000 Honda S2000
first start high pich whine noise
Old Jan 19, 2009 | 06:10 PM
barhonda_delsol's Avatar
Default first start high pich whine noise
ok so today i traveled to look at the s2000 that i put a down payment on. i cant get it yet cause i live in PA and the roads are bad and i couldnt even test drive it (damn snow). so i get to the dealer and they have it in the garage. its a 2000 s2000 with 100,000miles. im 18 years old so this doesnt bother me. but when i started it up there was a high pitch like whining noise coming from somewhere under the hood. it almost sounded like a fan running. but by the time i relized it and started to look for the noise it stopped making it. has anyone ever experiecned this before. it has an aem cold air intake on it and the rest is stock. its seen its better days but hey im 18 and i talked them down to $7,500. has clean carfax and clear title. looks like one corner panel had some work done to it at one point but other then that its a amazing car. if anyone can help me out that would be great. thanks
Old Jan 19, 2009 | 06:43 PM
AP1_man's Avatar
Default Re: first start high pich whine noise
sounds like chain tension
Old Jan 19, 2009 | 06:47 PM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
that is normal, its your fuel pump relay (if im correct)
it does this for about 20 seconds and turns off, then again for another 2 seconds
Old Jan 19, 2009 | 06:50 PM
thanks alot
Old Jan 19, 2009 | 06:57 PM
MidwestAutoWorks's Avatar
air pump
Old Jan 19, 2009 | 07:04 PM
ItsSlowYo's Avatar
Turbo? lol. jk jk
Old Jan 19, 2009 | 09:18 PM
andre@raw's Avatar
Originally Posted by MidwestAutoWorks
air pump
Yes sir it's you air pump located under the driverside headlight, and it will come on an off when you first start the car basically untill it warms up, nothing to worry about on the other hand be worry if you don't hear it at all but if that happends your check engine light will come on.
Your all good , go get it.
g/l
Old Jan 19, 2009 | 09:38 PM
AP1_man's Avatar
g/l
if this on the early AP1s? because I have never heard any noise like that come from my car.
Old Jan 20, 2009 | 06:55 AM
White Smoke's Avatar
i my honda
Global Mod
NO IT DOESN'T! Where are you getting this advise from man?
It's your secondary air pump. It pumps air into your exhaust manifold to prevent your catalytic converter from overheating thus shortening it's lifespan. And yes it is on early AP1's as well. You can remove the pump setup, but you will have a CEL. This will prevent you from passing emissions testing, if you have them in your area.
Old Jan 21, 2009 | 05:46 PM
thanks. getting it friday. ill be sure to post some pics.
Old Jan 21, 2009 | 06:40 PM
Jason.H.'s Avatar
dang, nice info guys. i didnt know what that noise was either. i thought it sounded like the ac compressor engaging or something.
Old Jul 3, 2010 | 02:28 PM
Durwin Sharp's Avatar
Different "whine noise" question: I have a 2001 S2k with 96k miles. It has a noticeable whine (like a bearing noise) that increases with speed. It changes loudness and pitch only with vehicle speed. It does not matter whether I am accelerating or decelerating, rocking from side to side, braking, or even if the engine is turned off and I'm still moving at 35mph. All 4 calipers have been removed and wheels rotated listening for bearing noise. Tranny and differential fluid are topped up, smell ok, and show no evidence of metal particulate. Have tried jacking first one rear wheel and then the other and running up to some speed, but still cannot replicate the problem while jacked. I think I have eliminated wheel bearings, tranny bearings (except perhaps rear bearing), differential bearings (except perhaps carrier bearings), brakes, and other stuff that I can think of. Any diagnostic suggestions would be gratefully received.
scubba
Honda S2000
17
Apr 1, 2008 12:53 PM
AnthraxVX
Honda S2000
Jun 21, 2007 12:32 PM
xandrake
Feb 7, 2007 08:12 AM
Ray2943
Honda S2000
18
Sep 23, 2005 06:23 AM
skierGT
Dec 12, 2003 01:04 PM
