Honda S2000 Honda S2000
S2000 Noise On Takeoff and Revers From DIFF?
Old Jun 18, 2007 | 03:02 PM
AnthraxVX's Avatar
Default S2000 Noise On Takeoff and Revers From DIFF?
im not sure if the noise is comming from the diff but it seems to be coming from the rear. When im in my garage and i back it out it sounds like something is binding and it makes a clicking noise AS i let off the clutch. It does it whenever i come from a stop.
ALSO when im in fourth WOMPING it on the freeway at about 115 or 120 or so the stick starts to Shake pretty bad. not shake but more like WOBBLE really fast side to side. as if the tranny was just occilating like crazy. someone said it is probably just because the freeway and the speed but the freeway seemed perfectly smooth. it has happened on multiple occasions
Thanks for the Help. im a new S2k owner. just got it 2 weeks ago>.. (2 speeding tickets already )
Old Jun 18, 2007 | 03:21 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: S2000 Noise On Takeoff and Revers From DIFF? (AnthraxVX)
Year of the car? Sounds like your axle nuts need to get re-torqued. 220lb feet. Take off the rear wheels, take off center cap, put wheels back on and car back on the ground, then re-torque.
Good luck on the speeding tickets.
Old Jun 18, 2007 | 03:50 PM
AnthraxVX's Avatar
its an 00 AP1 .. kk will do when i get home
Old Jun 19, 2007 | 06:35 PM
JUNEK9's Avatar
My 04 makes what seems to be the same clunk occasionally when i am at a stop and put the car into gear. Sounds like it is coming from the diff but I'm not sure.
Old Jun 19, 2007 | 09:37 PM
ReddotsS2K's Avatar
my shift **** shakes like crazy at any speed and i have gotten stopped twice also. the cop let me off both times and i was doing 90 and 86. i hope my luck continues. knock on wood.
Old Jun 20, 2007 | 11:09 PM
- BSeRiouS -'s Avatar
Default Re: S2000 Noise On Takeoff and Revers From DIFF? (ReddotsS2K)
IMHO, Your diff is about to fail
The ring and pinion is about to shatter in your diff case and you do not want shards of metal to be bouncing around in the diff housing. I had the same problem with my AP1
When coming to a stop, or taking off, it clicks, and makes weird chattering noises ever so lightly until you get on a higher speed and it tends to go away.
The ring and pinion (gearing) is not catching correctly. Lets hope this isn't it, because it is an expensive job to do.
I did this to the point where I drove it soo hard on upon any acceleration it "rumbles" my diff blew
Old Jun 20, 2007 | 11:20 PM
AnthraxVX's Avatar
Default Re: S2000 Noise On Takeoff and Revers From DIFF? (OBSeRiouSo)
any preventative things i can do? how hard is it to replace the gears inside? i can do it myself im sure i have an fsm and good knowledge on how to work on cars. rebuilt many bseries. not used to rear diff's but im sure i can do it . let me know. Thanks!
Old Jun 21, 2007 | 12:32 PM
^^^PM
Si_eg6
13
Aug 28, 2008 05:35 PM
bruce_s2k
Honda S2000
Oct 11, 2006 03:44 PM
jdmztrane
Jan 21, 2006 08:08 AM
SilverDC4
Sep 20, 2005 08:11 AM
