Highest F23 Dynos and 1/4 Mile Times
This thread will hopefully supercede BlkChryKord's "Highest F23 whp" thread which unfortunately turned to crap after turning into an F-series/H-series bashing debate.
Please keep all the bickering about 'which is better' out of this thread!
Here are some 'guidelines' that I'd like this thread to follow to keep it organized, informative, and on topic.
1. If you have numbers/times to contribute, please post them up along with a mod list. You don't have to list your painted valve covers or cool stickers, but everyone appreciates a detailed mod list.
2. If you have dyno charts or time slips to post up, please do include them in your post. Charts and Slips are HIGHLY recommended to prevent any questions or BS flags, especially if you are claiming some outrageous numbers. When I add you to the list in this first post, I will link your name to your actual post so that others can browse the list easily, without 100 photos to scan through on the first post.
3. Do not discuss H-series, hybrids, F22's, F20b's or anything else in this thread. This is to document F23's ONLY. If your post is filled with useless bickering, disparaging or derogatory comments, it will be reported to a mod, and deleted.
4. Feel free to ask questions and/or comment on fellow members' results, so that we all can learn.
I've started a few listings below, but the mods list and numbers are most likely out of date.
Boosted:
1. AFAccord - 416whp/397wtq
2. stinker504 - 364whp/350wtq
3. S1n1SteR - 344.6whp
4. hotaccord243 - 332whp/335wtq
5. EmminoDaGreat - 265.4 whp/253.15 wtq
6. NotoriousB - 242whp/268wtq
7. accord99power - 236.57whp/255.69wtq
1. demon5spd - 301whp/310wtq
1. AFAccord - 176.1whp/170.1wtq
2. NASOHC - 174whp/171wtq
3. Sonnick - 156.9whp/~145wtq
Boosted:
- Wiseco K20 Pistons (10.5:1)
- Crower Rods
- Stock Head
- Stock Cam
- Stock IM/TB
- SwainTech Ceramic Coatings
- MFactory LSD
- A lot
- A whole lot
- SC34 @ 16psi
- AEM EMS
- Fully Built F23
- 9psi
- Stock F23
- Drag t3/04b @ 12psi
- 10psi
- 50A/R .63TRIM T04E
- Gude Camshaft
- CP pistons
- Crower Rods
- Maxbore TB
- ARP Headstuds
- AEM Cam Gear
- ZEX wet kit - 125 shot
- Bisimoto Level 2 Cam
- Bisimoto valve springs & retainers
- Skunk2 70mm TB
- H23 Intake Manifold
- eBay Header with 2.5" collector mod
- 2.5" Custom Exhaust
- P61 OBD1 ECU with OBD2-OBD1 Harness
- Milled head (.040") with mild port work
- H23 Trans with F23 5th gear
- AEM Cam gear
- Wiseco Pistons -5cc 10.69:1 comp
- Portmatched head and Intake Manifold
- Bisi Valve Springs
- 68mm TB
- Balance Shaft Delete
- WebCams Camshaft
- AEM V2 intake
- Adj Fuel Press Regulator
- DC Header
- UR-Ultra Crank Pulley
- AEM EMS
- WSII Exhaust
- Intake
- Header
- Exhaust
- Exedy stage 1 clutch
- Fidanza Flywheel
just curious, how come your A/F ratio are so erratic. arent you having a problem running rich? Shouldnt your A/F ratio be somewhat of a straight line exspecially since your NA and do not need to run rich to compensate for the boost?
just a thought
just a thought
His car was using the stock ECU in that dyno, so it's not tuned. The graph also exaggerates it because of its small scale and large height.
That's no where near stock. More like a 25-35whp increase over a stock F23 with manual transmission. Not many people ever see those numbers from their F23 with just bolt-ons.
hey! cool idea with the thread, and to keep it strictly F23! awesome! BTW just ran across this and thought Id update my number, I'm now at 332 whp and 335wtq @ 16psi
Here's my last print.
98 Accord - F23A4 ULEV stock NA Motor on Webcamshaft, V2 CAI, Adj. Fuel Press. Regulator, DC Header, an UR-Ultra Crank Pulley tuned on AEM Management System, and WSII Exhaust w/a Cat!
Also: H23 Trans. Swap & Exedy Stage 1 Clutch.
I had changes done to AEM unit that affected driveability and tuning a bit; also had catalytic converter removed, an aluminum flywheel and 6 puck clutch installed after this test but never dyno'd car again since. I'm sure it's above 160 by now but we'll have to wait until next dyno session.
153.8 whp/152.7wtq.
153.8 whp/152.7wtq.
Cam is in. I somehow managed to loosen the timing belt while swapping it out, so it has a nasty flopping sound when running. It does pull nicely, but didn't give me that 'whoa!' feeling. I'm sure after a good street tune it will feel much better, but it might be a while before I can dyno tune and have numbers to post.
The head is slightly ported on the exhaust side with a good bit of smoothing, and only deburred on the intake side with a little smoothing, then milled maybe .030" by my guestimates.
I`ve used the stock cam up until now. The new cam feels a little more peppy around 3000 rpm, but thats about all. Hopefully it will really wake up with a good street tune.
