Highest F23 Dynos and 1/4 Mile Times
#77
#78
Re: Highest F23 Dynos and 1/4 Mile Times
Looking to get a re-tune that's much more aggressive come spring time....
Hopefully push some really nice numbers....
Also gotta get new tires so i can take it to the track come spring too....
Good info in this thread, and congrats to everyone pushing some great numbers NA/Nitrous/Turbo and all!
#82
Ok Jason,
Looking to update here and bump this thread.
Results from new build:
Wiseco Custom Pistons (-5cc) est. 10.69:1 Compression w/stock head, basic Pnp Headwork (gasket match), Bisi Spring kit, No balance shafts, on 91 pump octane - everything else was left the same as last dyno; bolt-ons and same WebCamshaft.
All components used are original from motor. Running A/C, P/S.
Thanks Bisi again for the fine tune!!! 171wtq/174whp F23A1 VTEC N/A
#83
Updated first page Ken!
I might have to go make another dyno run with the exhaust cutout and cool weather just to put a little more distance between you and I.
#84
AFAccord: i'm interested in your cam mod. do you have a thread about it? any videos of the cammed sound?
I'm thinking about doing this to smooth out my partial throttle map a bit. The crossover is a little rough.
#85
Don't temp me man.
#86
http://www.youtube.com/watch?v=9bNLQptMTdA
#87
That is the third Bisi dyno chart I've seen that has a schizophrenic torque curve. What is the deal with that?
This is a great thread. Linking the build threads would be a great idea for the first post.
#88
If anything, the dotted line (previous setup) has a bit of a dip in it, but I believe that was because they set VTEC engagement so high. It's much smoother on his new build, since they lowered it some. On that note Ken, why don't you ask Bisi to lower it a bit more and add a little timing the next time you're on the dyno? I can almost guarantee that you will eliminate that slight dip and probably pick up a few hp in that midrange.
#89
I understand the scaling, I'm talking about 3 different hiccups throughout the graph. The worst being almost 1,000 rpm's long, resulting in a 7 ft/lb loss right at the apex. You can't tell me that's from vtec kicking in.
Maybe it's just me, but I would be concerned about a 4% loss where my VE should be the highest.
#91
The charts you see from Bisi aren't making wacky torque curves, it only looks that way because of the scaling. Ken's torque plot goes from 119 to 171, while the hp plot is 0 to 180.
Thank you for the comments!
#92
almost forgot about this thread. I want to pull and start building the f22b1(yes its not a f23), but its close enough. AFA did you sell/or are you still selling your bisi stage 2 cam? If I sell my JRSC I will begin buying parts for the f22b1 and pull it from the accord in my driveway.
#93
At this point, I'm not interested in selling it unless my next build requires something more aggressive. I've never seen hard proof that the F23/F22b cams are interchangeable, if that's what you're implying.
#94
Right now im looking at Delta, Web and Bisi Camshafts. I know you are running a Bisi camshaft and NASOHC is running a Web camshaft. I dont think I have seen any vtec delta camshafts yet for f-series.
If I do get a chance to start this build its going to be slow. Camshaft and springs and then pistons. Eventually i want to be around 225-250whp. Im thinking that i can reach that on 12:1 compression, just not sure yet on the cam. Also wondering if it will be possible with only doing gasket matching for porting. Car will be feed E85 as a DD when its done.
Forgot to mention that I do want to rev some where between 7500-8500 while using my GSR trans. F2B
#95
Definitely good results. I'm sure it rips. I always love that feeling when you get it together and really get on it the first time. Pride and joy.
#97
First post updated. I know there are some updated numbers from some of you already on the list, so post your updates! It would be nice to see some 1/4 mile times up there too!
My contribution to the list of boosted F23s:
Green: 5psi
Purple: 13psi
Blue: 19psi
Green: 5psi
Purple: 13psi
Blue: 19psi
#98
I know this thread been long dead but just thought I would share my results all the way from Africa. Stock F23, only has exhaust, 60mm throttle body and vtec is locked/deleted, and its mated to a Ls transmission on a Eg sedan. Motor was rebuilt fresh. Has about 100kms on it. 152whp 179wtq.
slvrcivic97
10-28-2002 12:27 PM
