Gas Smell
Old Aug 6, 2002 | 12:39 PM
beakert216's Avatar
Default Gas Smell
When I fill my gas up to full. i can smell fuel when i roll down my window. It only does this when my gas tank is full. Help please, can't stand the smell.
Old Aug 6, 2002 | 01:14 PM
brcivic411's Avatar
Default Re: Gas Smell (beakert216)
maybe because you get gas on your hands...
here's my theory:
The only time you smell gas is when your car is full. The only time your car is full is after you've gone to the gas station to fill up. At the gas station (unless you're from NJ) you pump gas. As you're pumping gas, gas may be getting on your hands/clothes/etc.
OR...
check your fuel lines. make sure they're clamped down, screwed on.
Old Aug 6, 2002 | 02:44 PM
Chiovnidca's Avatar
What year and model?
Old Aug 7, 2002 | 04:40 PM
beakert216's Avatar
Default Re: Gas Smell (Chiovnidca)
97 civic
Old Aug 7, 2002 | 05:10 PM
Chiovnidca's Avatar
97 civic
I can't think of any known problems. You'll just have to follow your nose to narrow it down and start inspecting from there.
Old Aug 7, 2002 | 07:20 PM
saso
Guest
Posts: n/a
mixture can be too rich depending on if you running stand alone. Check fuel lines and FPR, check diaphragm on FPR.
Old Aug 7, 2002 | 10:24 PM
hydroflip's Avatar
Default Re: Gas Smell (saso)
if you look in the haynes manual it says that if you overfill your tank at all you will smell a fuel odor...so its normal.
Old Aug 7, 2002 | 10:31 PM
beakert216's Avatar
Default Re: Gas Smell (hydroflip)
hydroflip. i think your right. i have no leaks at all. so that has to be it. thanks for the help guys.
Old Aug 8, 2002 | 06:27 AM
LTB420's Avatar
when you over fill your tank the extra gas go's into the charcol tank to be evaporated away.
Old Aug 8, 2002 | 08:08 AM
AutoXsi2000's Avatar
try gas X or turbo lax. hehehehe, j/k.
delante(ej1)
Apr 7, 2013 10:10 AM
TealCivic93
Apr 8, 2006 09:31 AM
HondaHemi
Dec 3, 2005 05:51 PM
null.
Jun 22, 2005 07:03 PM
E-Rok
Dec 26, 2003 12:55 PM
