MY Alignment Setting !!
my car had been lower and change the new tires so done the Alignment today and c wut u guys think? how's that compare to the stock setting? any info appreciated thanks
Before :
Front Total Toe: 0.06
Front Steer Ahead: 0.15
Front Right Camber: -1.98
Front Right Caster: -0.02
Front Right Toe: -0.12
Front Left Camber: -1.50
Front Left Caster: 0.09
Front Left Toe: 0.18
Rear Total Toe: 0.46
Rear Thrust Angle: 0.11
Rear Right Camber: -1.48
Rear Right Toe: 0.13
Rear Left Camber: -1.37
Rear Left Toe: 0.34
After:
Front Total Toe: 0.15
Front Steer Ahead: 0.00
Front Right Camber: -1.97
Front Right Toe: 0.07
Front Left Camber: -1.51
Front Left Toe: 0.07
Rear Total Toe: 0.25
Rear Thrust Angle: 0.01
Rear Right Camber: -1.49
Rear Right Toe: 0.12
Rear Left Camber: -1.47
Rear Left Toe: 0.13
[Modified by TillerMan, 9:39 PM 8/6/2002]
Before :
Rear Left Toe: 0.34
After:
Rear Left Toe: 0.13
that alignment is horrible. kiss those tires good-BYE!
too much toe and i think the variation in the front camber is too far off.
Type-Rare#1248: i like the tires but haven't try hard yet since i haven't break in the tires gona wait after 600kms to try it hard
i just called the shop whondid my alignment he told me the reason he set my car's toe to 0.07 it's because my car had been lower and he set that to prevent wear the tire that fast and i asked him wut if u adjust that to 0.00 for the front toe he said yea i can do that but the tires will wear faster since i am not using the stock spec .. that's wut the technician told me.. but i think it feels good after done that .. thanks for u guys info
[Modified by TillerMan, 10:48 PM 8/6/2002]
Anyway, there are a lot of alignment techs that think that camber wears out your tires, when in fact it is toe that does. So by giving your car toe, they can make the camber "better" and think they are saving your tires when in fact it is just the opposite. HTH
i think this is really confused me .. dunno if i should let them adjust the toe to 0.. well camber can't do anything about it .. unless i have the front camber kit..
Tell them to set the front and rear toe to 0 total toe. It's a good starting point, it also gives you maximum tire life. From there you can work your way out or in after getting some track time.
CB
CB
CB
CB
Vwong, I have similar variation in my camber -1.3 F left to -1.9 F Right
I also have 1/8" toe out in the front and zero rear.
thanks for ur advice of starting point .. so if i change the front and rear's toe to 0.00 wut will the camber be? so ppl who lower thier car u guy's front and rear total toe = 0.00? thanks
AzntaggeR
18
May 1, 2004 03:21 AM
