Strongest Axles PERIOD for a H22a prelude...
I have lost 11 points on the last 2 races due to blown CV joints in my driver's side left axles.. I need to know the best axles out on the market... Please help me out guys..
First damn thing I thought.
Hi Corey!
Sorry to see you broke the axle again....
It seems unlikely to me that the axle should be failing just by racing hard... Have you made any other changes to the car? Lowered it alot recently or changed the suspension? Changed brake systems (more heat into the hub?)?
Even a stock axle should stand up to more than 1 day of racetrack use.... Something must be going on with your car.... I mean, you ran it how many weekends prior to this, with no problems, and now suddenly you blow up 2 axles in 2 weekends?!? Something else is going on! If there is a problem, trying to install a super strong axle will be like a bandaid fix for the problem, and most likely something else will break instead
Good luck figuring it out and will see you at Lowes.
Todd Reid
#11 H1 Honda Civic DX-LS
Todd Reid
crazybeanery0
Jun 15, 2007 02:43 AM
