Some times car wont crank!!!
Old Jan 13, 2009 | 12:38 PM
S2kool's Avatar
Default Some times car wont crank!!!
What do you guys think it is?
Everything is normal when I put the key in all lights on the dash come up, windows and radio still work fine so its not the battery?
When I turn the key nothing happens just the dash lights flickers, then after several tires, I remove the key put it back in then it works.
Is this a bad starter? battery? ignition?
Thanks for any inputs.
Old Jan 13, 2009 | 01:19 PM
unrivaled's Avatar
Default Re: Some times car wont crank!!!
check the wiring going to the starter make sure they are not loose, second the next time this happens tap on the starter a few times and see if it starts up. hope this helps
Old Jan 13, 2009 | 01:42 PM
92IntegraPOS's Avatar
replace the wire from the valve cover to the front of the car by driver head light. to prove my theory next time it wont start have someone hold a piece of wire from the point were the wire starts on valve cover to a good body point and try to start it.
Old Jan 13, 2009 | 01:53 PM
krucial7integra's Avatar
yes, if the female connector is not plugged up to the starter, then this could cause the problem. Banging on the starter can also determine if you have a bad starter also.
bigboi407
Apr 9, 2016 04:27 PM
EFjoe91
Apr 30, 2014 05:49 AM
BDC2
Jun 17, 2010 08:17 AM
4tika4
Jun 13, 2009 02:21 AM
pizzle
May 2, 2008 06:38 AM
