AC troubleshooting
Old Aug 6, 2002 | 06:39 AM
nixadm's Avatar
Default AC troubleshooting
I need some help with my AC.. it's blowing hot air
I checked the presure on the high and low systems, the low is at like 45, which is a little low and the high is at 85 which is very low I think... when I turn it on the fan and compressor kicks in. My question is, would those low presures cause it to blow hot like that? if so what's all invovled in refilling the high presure system, I think I found where it was leaking (right where the plastic hose turns to metal before the radiator)
before it starting blow hot air, it would intermittently blow hot air, but was mostly cool.
Thanks in advance
Old Aug 6, 2002 | 10:22 AM
CivicNewbie's Avatar
Default Re: AC troubleshooting (nixadm)
If you have a 5G Civic, 94+ Teg, 94+ Accord, I would guess your A/C compressor is bad or your expansion vavle stuck open.
Old Aug 6, 2002 | 11:20 AM
jetdriven's Avatar
Default Re: AC troubleshooting (CivicNewbie)
try adding more refrigerant befor replacing anything. its the cheapest way to troubleshoot. low should be 30-45 but the high side should be 110 over ambient, 200 is a good number. If the low side is high and the high side is low you may have the expansion valve stuck open or you have a bad compressor. good luck
Old Aug 7, 2002 | 04:26 AM
nixadm's Avatar
Default Re: AC troubleshooting (jetdriven)
How do I check my valve?
how much can I expect to spend on a new compressor
thanks
Old Aug 9, 2002 | 09:55 AM
nixadm's Avatar
anyone?
Sammy24
Honda Civic (2001 - 2005)
Aug 19, 2018 01:18 PM
arielb1
Jul 15, 2017 04:43 PM
triet43
Aug 10, 2014 06:09 AM
Roddogz28
Jul 1, 2013 10:17 AM
Muckman
Jun 1, 2011 10:59 AM
