honda mtf
Old Jan 12, 2009 | 07:28 PM
civicgsr499's Avatar
Default honda mtf
i was just reading all these topics about how using honda mtf or synchromesh clears up grinding gears. i have 3 quarts of acura mtf in my room and an ls tranny with a bad input shaft bearing. do u guys think if i put in the mtf that it would help clear it up in there or is the damage done already?
Old Jan 12, 2009 | 07:34 PM
vietnamezerice's Avatar
Default Re: honda mtf
depends how bad your tranny is... i would get 3 quarts of Pennzoil Synchromesh from autozone and use it and drive it lightly going through all the gears and see if it helps... are you using an aftermarket shifter?
Old Jan 12, 2009 | 07:38 PM
nope... its stock
Old Jan 12, 2009 | 07:39 PM
ok cool just making sure... sometimes the aftermarket shifters will throw off the geometry of the linkage causing the synchros not to work properly and in time damage your tranny
Old Jan 12, 2009 | 07:43 PM
i think ur misunderstanding me... i dont have any grinds, just a bad ISB, which makes the tranny make a whining noise
Old Jan 12, 2009 | 07:51 PM
oh!!... only way to get rid of the noise is if you replace it... sorry man at least the noise goes away when you step on the clutch :p
Old Jan 12, 2009 | 07:57 PM
haha i know right... i hardly ever downshift into 1st and 2nd anymore. the noise is so annoying. well im plannin on picking up a gsr tranny within the next couple weeks so thatll be an upgrade at least
Old Jan 13, 2009 | 04:29 PM
that's good.. good luck on the project man!
Old Jan 13, 2009 | 04:40 PM
thewrai6th's Avatar
The damage is done, replace the ISB and all the other bearings. Otherwise, you'll end up with bearing peices from the ISB in your other bearings and have to do it all again.
No fluid can fix a burnt ISB, the bearings are probably not even round anymore.
Old Jan 13, 2009 | 05:52 PM
Romo Pyro's Avatar
^ knows his stuff.
Here lemme show you what he means.
1997 Integra GS-R ISB. Approx 130-140k miles.
Old Jan 14, 2009 | 07:57 AM
yeah i just changed the tranny fluid about 2,000 miles ago and there were no metal shavings. the isb prolly just started to go bad. im just gonna take the safer route and get a new transmission
Laish
25
Nov 15, 2012 05:41 AM
Louie
Honda S2000
Dec 29, 2004 06:09 AM
willyboyK20
Aug 23, 2004 05:27 PM
ahc'monracing
20
Mar 4, 2003 06:44 PM
dirtySOHC's
Jan 11, 2002 03:40 AM
