No Start
Old Aug 5, 2002 | 11:22 PM
Malgerus's Avatar
Default No Start
Well, I'm once again plagued by the curse of Y-49 (yellow CRX).
Here's my problem. The car will start for a few seconds, then die whether I give it gas or not. It was idling rough before but at least it ran. I was thinking the IACV, and I was getting a code 14 earlier (IACV), but if this was the problem shouldn't the car run after I give it gas?? The fule pump is new, tested the main relay... what else should I do?? I noticed I had a loose wire on my converter harness... But I fixed that and it was no help! I'm at my wit's end here... help anyone??
Just so you know I have an 89 CRX Si witha 96' D16Y8 running off a P28 ECU.
Old Aug 6, 2002 | 12:10 AM
raene's Avatar
Default Re: No Start (89_Y_49)
Does this look right? This is how his cam looks at TDC, could it have skipped a notch? The belt is tight.
How his car sounds while starting
Old Aug 6, 2002 | 02:37 AM
LsTurbo91's Avatar
Default Re: No Start (raene)
damn i'm sleepy , it looks off though.
Old Aug 6, 2002 | 11:21 AM
Malgerus's Avatar
Default Re: No Start (LsTurbo91)
Anyone else???
Booz
Mar 26, 2012 09:37 PM
dubzz24
Mar 2, 2007 09:14 AM
CRXCRAZYD16Y8
Feb 8, 2007 11:51 AM
CRXCRAZYD16Y8
10
Feb 11, 2006 07:15 PM
CRXCRAZYD16Y8
Feb 7, 2006 04:09 PM
