96 EX 2dr, CV problem perhaps?
Old Jan 10, 2009 | 09:38 PM
KSWEST's Avatar
Default 96 EX 2dr, CV problem perhaps?
I was out and about day before last, going through a parking lot to pick up some computer stuff. I noticed an odd noise coming from the left-front of my car, so I turned down the music a bit, and everytime I turned left my car would make a "wobble/thumping" noise. I thought it might be the undercarriage protection that got destroyed last year in the snow shaking loose again but after further inspection it was all still intact. I assume the worst and that my CV axle is shot to hell. Sound familiar or anyone have a better idea?
Old Jan 10, 2009 | 09:44 PM
The_Honda_Guy's Avatar
Default Re: 96 EX 2dr, CV problem perhaps?
Does it do it when the car is sitting still and you turn the wheel left to right? Does it do it when you're turning and the car is going forward?
Old Jan 10, 2009 | 09:46 PM
KSWEST's Avatar
definitely when i'm turning left and going forward, not right though. Haven't sat still and tried it, considering it just dawned on me after i got off work today.
Old Jan 10, 2009 | 11:28 PM
KSWEST's Avatar
Bump for any help
Old Jan 11, 2009 | 08:51 AM
Axle shaft then. If it doesn't do it when you're sitting still and turning the wheel left and right but only does it in motion during a turn then it's definitely an axle shaft, most likely the outboard joint on your left front. Just hop on down to Advance Auto or your local parts store and pick up a brand new axle for like 60 bucks with lifetime warranty. Most likely the boot is either ripped open and threw all the grease out (which is how they usually fail) or you were wheel hopping the car and blew it out.
Old Jan 11, 2009 | 08:04 PM
KSWEST's Avatar
Originally Posted by The_Honda_Guy
...wheel hopping the car and blew it out.
I wouldn't put it past it being this one, considering the outlandish 71" of snow we got in december, and without the plows doing there jobs, it turned to ice chunks and made the roads disgustingly uneven, thus any momentum trying to keep from being unstuck made some serious wheel hop. I will go into work this friday and pick one up for like $35. Hooray for working at Napa....
Old Jan 11, 2009 | 09:08 PM
Yea, wheel hop owns FWD axle shafts and differentials. My friend blew both the axle shafts out of his 2001 GSR wheel hopping the **** out of it at the 1/4 mile track. Unfortunately the first thing he blew out was the GSR trans, which was then replaced with a Type-R trans. LSD = both wheels spinning and both axle shafts breaking. lol At least you didn't blow out the diff, that would be much worse than the axle shafts. lol
Old Jan 11, 2009 | 10:08 PM
KSWEST's Avatar
yikes. I only face the minor problem now, getting a place to install it. Sucks living somewhere where i know nobody with a shop or even a decent garage with tools...
Old Jan 11, 2009 | 10:25 PM
Axle shafts can be a bitch to do on jackstands, especially with a cold garage. I just did my friend's 86 Scirocco axle shafts in my 10 degree garage and it wasn't very fun, especially since all the bolts had been stripped out and tampered with before I got to them. It wouldn't be as bad doing them on a Civic compared to that car, but jackstands suck when doing any major work, especially when you're freezing your *** off.
Old Jan 11, 2009 | 10:49 PM
KSWEST's Avatar
I actually talked to one of my co-workers, he said for a case of beer i could come use his lift and his huge shop. *crosses fingers* hopefully my car can last until we get a joint day off.
Old Jan 11, 2009 | 10:54 PM
That would definitely work out well for you. You can keep driving the car as long as you don't completely **** up the joint and seize it. I'd hate to see what would happen if you seized the joint complete and snapped the shaft off while driving. lol My friend's was so bad that when I pulled the shaft out of the knuckle two of the ball bearings in the CV joint FELL out of it, like literally just fell out of the joint onto the floor. You know you've waited a little too long to change it out when that happens. lol
Old Jan 12, 2009 | 08:44 AM
KSWEST's Avatar
bahahaha. thats just bad. i don't think mine has quite gotten to that point yet, especially with me being able to take the city bus everywhere. I'm just gonna keep my fingers crossed either way though, not the ideal day for me.
Old Jan 12, 2009 | 08:53 PM
KSWEST's Avatar
I went out this morning and it was fine turning left and right at a stand still so i'm about 99% sure that it is in fact my left drive axle....*sigh* just what i need right now
Old Jan 12, 2009 | 09:33 PM
Yea, most likely it's your left side (driver's) axle shaft. Just need to get a shaft and replace! Before you start though, I'd check out the condition of the right side one too. If the boots are getting dry rotted or have any holes in them, replace them both. Also, if it's got play it in replace it then too.
Old Jan 13, 2009 | 10:19 PM
KSWEST's Avatar
yah, i figured for like 35 a pop since i work at napa, i might as well end up doing both. It just seems like a wise decision at this point in time.
jesssssking
Apr 24, 2015 08:50 PM
remo
Mar 28, 2005 12:51 PM
rhetorical
Nov 29, 2004 11:45 PM
Accord_Kid
Aug 25, 2003 10:45 PM
REDBARON
14
May 24, 2001 07:25 PM
