Can't get into gear.
Old Jan 10, 2009 | 01:12 AM
KayTran's Avatar
Default Can't get into gear.
I can't get into gear when my car is on. It's as if my clutch will not engage/grab. When I start my car in gear, it flies and then stalls. Fluid levels are good, I have bled my clutch, tranny fluid level is good. What could be my problem? clutch? engagement point? transmission? Thanks.
Old Jan 10, 2009 | 01:31 AM
majinsoftware's Avatar
Default Re: Can't get into gear.
Pressure plate or clutch plate springs fallen out.
Old Jan 10, 2009 | 11:27 AM
KayTran's Avatar
ohh, so does that mean i am going to have to take off my tranny and what not to examine the clutch?
Old Jan 10, 2009 | 01:31 PM
StokelesS_g2's Avatar
No need to examine it, just replace it.
Old Jan 10, 2009 | 04:13 PM
KayTran's Avatar
I bled my clutch once again today and could get into gear once again but the downside is I think I am getting a lot of air. I am constantly consuming air to the point where my pedal feels like it has a lot of freeplay. My engagement is also as high as ever, i've tried adjusting it, but the engagement just won't go down. What is my problem now?
Old Jan 10, 2009 | 05:01 PM
OldSkoolDa91's Avatar
sounds like you need either a new clutch slave cylinder or master cylinder then if you keep getting air in constantly...
Old Jan 10, 2009 | 05:03 PM
pkdog167's Avatar
Check your master and slave clutch cylinder for leaks.
Old Jan 10, 2009 | 05:11 PM
KayTran's Avatar
Looks like I have no leaks at all...
Old Jan 10, 2009 | 07:06 PM
vietnamezerice's Avatar
sometimes the master or the slave can leak internally and you wouldn't be able to see them... bleeding a system shouldn't take but a good 3-5 times to acheive pedal pressure and that should be sufficient for clutch engagement/disengagement... I've had a clutch disc go bad on me and I couldn't shift either, but it also made alot of noise... hope that helps bro
Old Jan 11, 2009 | 02:16 AM
KayTran's Avatar
Thanks bro. I'll look into it more
mrcoolhead
Jan 30, 2013 06:12 PM
EKcpe00
10
Jan 24, 2011 05:51 PM
codybb4
Dec 9, 2008 08:44 AM
viet_tec
Mar 20, 2007 12:54 PM
t0mmysays
Jul 6, 2006 10:21 PM
