225/45/16 will it rub?
hey guys.....i was wondering if 225/45/16 will rub on my integra, i'm lower on tien s.tech. I don't really care if it rubs when i'm doing a u-turn but i can't have it rubbing when i'm making a turn....thanks!
205/45/16 is preferred
stock size 195/55/15<< 195mm(width) x .55%(aspect ratio)=107.25 x2=214.50/25.4mm in an inch=8.44 + 15(rim size)= 23.44 inches overall diameter
205/45/16 = 23.23 inches
225/45/16 = 23.97 my experience tells me it would rub, no matter the price on the tires a rolled up fender is not worth the savings plus you have to factor in the offset and backspacing of the wheel 225 may be to wide and rub when you hit every little bump in the road
I remember a thread showing a stack of 225 are taller than 235 tires...
The best way is to go to tirerack to check with the diameter
are you talking 225/70/16 compared to a 235/45/17??? or the circum. of the tire
215/40/17 Z1 Sport wider than 225/45/17 RT615
http://sccaforums.com/forums/10/291603/ShowThread.aspx
sorry cant believe it without seeing it in person, not by that much, and as far as the height on the 15" in the review tread depth could easily factor into that, tread depth would account for almost 1/2 to 3/4 of an inch but im gonna be comparing tires when i get back to work we stock approx. 3500 tires at my work and ill let you know
Yup, they'll rub. Stick with either 205/45-16 or 215/45-16. Both are within 1 percent of the outer diameter of the stock 195/55-15 size. If your Integra came with 195/60-14 tires, then 205/45-16 is closer in diameter to stock than 215/45-16. Don't get the 225/45-16.
