Help with fuel pressure
Old Jan 7, 2009 | 01:58 PM
b20beast83's Avatar
Default Help with fuel pressure
Hello everyone, i have a disturbing problem
Car is 99 Si
B16a Engine
Stock fuel pump
Aeromotive fpr / marshall guage
I was looking at my fuel pressure, bolted on my aeromotive.
It read about 38 psi with vaccum line attacked and
42psi with it removed.
I try to adjust the pressure past 42psi and it wont budge, it might even go below 42psi by adjusting the regulator.
Does this mean my pump is weak?
Old Jan 7, 2009 | 04:16 PM
b20beast83's Avatar
Default Re: Help with fuel pressure
12 views no post?
Old Jan 7, 2009 | 04:23 PM
fcm's Avatar
fcm
Old Fart
Fuel pressure should be around 28-36 psi and 38-46 psi with vac. hose disconnected, sounds like you are within parameters. 94
Old Jan 7, 2009 | 04:53 PM
b20beast83's Avatar
also when i prime the pump, the guage drops to 0 very quickly
and car off it drops to 0 in some seconds
but from vac connected then disconnected its only a 2psi change, it should be at about 10psi jump
Old Jan 7, 2009 | 07:09 PM
mmuller's Avatar
Mad Scientist
could be a faulty regulator, or as you say fuel pump, but if the fuel pump is having such problems on keeping pressure up at idle ; then it would have a great impact on drivability.
pressure dropping so fast could be a faulty regulator or the usual pump valve
you can amp test the pump to see how much is using
Old Jan 8, 2009 | 04:50 AM
b20beast83's Avatar
How do i test the pump?
do the aeromotive regulators go bad?
Old Jan 8, 2009 | 12:31 PM
tech7427's Avatar
as said before you can check to see how many amps the fuel pump is using, a worn pump will use more amps to run to produce the same pressure. you can actually put a lab scope on the pump leads and watch the graph and you can actually see the waves moving adversley, showing warn pump.
sounds like the regulator is bad.
crimp the return line, turn the key on,and see what the pressure does now, if it stays up it is a faulty regulator if it drops fast then the pump is bad.
cheers.
Old Jan 9, 2009 | 04:26 PM
b20beast83's Avatar
pinched the return line, and pressure rise
this means the pump is weak?
Old Jan 9, 2009 | 04:30 PM
Evs-One's Avatar
Solbros Owns Me
regulator is bad...it's allowing more fuel into the return line than it should.
Go back to stock.
Once you have pressure in the rail, it shouldn't drop unless the injectors are leaking(most likely not), or the FPR is letting fuel by....
Old Jan 9, 2009 | 04:50 PM
b20beast83's Avatar
what about the fuel filter
could this be a factor?
Old Jan 9, 2009 | 04:56 PM
b20beast83's Avatar
what is the pump valve?
Old Jan 11, 2009 | 02:52 PM
b20beast83's Avatar
Ok guys thanks for the info
It was the Fuel Pump
TurboSpoolinInside
Jul 24, 2011 06:06 PM
scuffywin
Jun 5, 2007 04:15 PM
Dat1BVtecN
Mar 19, 2007 07:43 PM
BoOsTiN Dc2
Feb 1, 2005 10:05 AM
SLOAZZ95
Aug 5, 2004 04:29 AM
