Re Surfacing steel?
Old Jan 5, 2009 | 11:11 AM
m R g S r's Avatar
Default Re Surfacing steel?
My table top of my welding table is pretty rough. I mean its straight, but just rough. I hit it with the wire wheel which helped to clean it up a bit, but when you look at it up close it almost looks pitted?
I think its an old road plate, not even sure of the material, just know its steel.
Anything I can do to smooth it out?
Old Jan 5, 2009 | 11:50 AM
hoya_10fintec's Avatar
Default Re: Re Surfacing steel?
mill it... or just go wild with angle grinder w/polishing(hard) wire wheel.
If that doesn't help and it still bothers you, get a new one.
Old Jan 5, 2009 | 12:12 PM
QuangAlang's Avatar
weld a new thin plate on top
Old Jan 5, 2009 | 03:00 PM
Blackcatn2o's Avatar
x2
Old Jan 5, 2009 | 04:03 PM
*Boostwerks*'s Avatar
40 grit flap disc
Old Jan 5, 2009 | 04:56 PM
Luserkid's Avatar
We hit our welding tables with 80 grit random orbit. If its really bad well bust out a 120 grit on the 5inch grinder. And once in a while we wax the tables.
Old Jan 5, 2009 | 05:03 PM
ToxicFabrication's Avatar
OG Fabricator
Originally Posted by *Boostwerks*
40 grit flap disc
thats what i use
Old Jan 5, 2009 | 05:04 PM
punkinbeck's Avatar
to get my table really flat I use a big 9 inch grinder with a grinding wheel.. Run it totally flat on the table.. It will hit all of the high spots.. side to side, then up and down, but from the sounds of it this isn't exactly the finish you're looking for.
Old Jan 5, 2009 | 10:50 PM
m R g S r's Avatar
I'll try the flap disc see how that works. milling it will be kinda hard because the only way it will come out of my basement is in pieces lol
and worst case i guess i could just get some thin sheet and weld it on top of the beastly plate
Old Jan 6, 2009 | 01:13 PM
CTD-Fab's Avatar
I have an 1/2 thick aluminum table and i love it, wouldn't go back to steel ever again.
I vote bolt on an aluminum plate
Old Jan 6, 2009 | 01:45 PM
m R g S r's Avatar
that sounds expensive...im not looking to spend a lot more money on the table
Old Jan 6, 2009 | 01:53 PM
punkinbeck's Avatar
The big grinding wheel running flat works really nice. I promise It's almost as nice as getting it milled when done right
Old Jan 6, 2009 | 02:01 PM
Do you tig on it? Aluminum table plate + tig welding = most guys getting zapped.
Old Jan 6, 2009 | 06:11 PM
CTD-Fab's Avatar
Yeah, i only tig on it and don't have any problem getting shocked @ all. Plus is doesn't scratch parts because its a pretty soft series and parts don't arc and stick like steel.
I have covered a few other tables with thin sheets and it works pretty much the same.
The other benefit is thats it warms up nice and fast with a small foot heater underneath for winter fabbing
Old Jan 6, 2009 | 09:41 PM
downest's Avatar
I miss working on an aluminium table. I never really had issues with getting zapped, and I am starting to get annoyed using a steel table now with stuff arcing to it. If I can find a good thick sheet I'll bolt it down on top of the table.
Old Jan 9, 2009 | 02:16 PM
legendboy's Avatar
lol whats your reasoning on this??
91EFH22
Paint and Body
20
Nov 12, 2012 04:45 PM
contractkiller
Welding / Fabrication
Apr 25, 2012 08:51 AM
ozh_hawaiian
Jul 18, 2010 04:24 PM
BEEYOND
Feb 22, 2006 05:30 PM
The Kernel
Oct 11, 2001 04:08 PM
