Do you know your ecu's?
Old Jan 4, 2009 | 11:09 PM
Auth-ITR-Widow's Avatar
Default Do you know your ecu's?
Ok, since I was not the one picking all the parts on my baby, I am not sure which one it was so maybe someone here can help me out. I will need to get this on the new car, when I am able to build/buy...
This ecu enabled the vtec to be programmed to start earlier and also made the rpm no longer redline at 8700 but redline at 10k.. vtec would kick in at 4900 an stayed on from 1st gear till you let off the gas. This also disabled the air conditioning so it was removed, but I was able to keep power steering. After it was put in, it had to be dyno'd to program it and the unit was about 1000 bucks.
This along with all the bolt ons and internals turned it into a roaring monster. I must have another..
Any ideas?
Old Jan 5, 2009 | 05:53 AM
CW-ITR's Avatar
Default Re: Do you know your ecu's?
Sound like a re-chipped ECU with a custom program.
Old Jan 5, 2009 | 11:38 AM
tnkw's Avatar
maybe the spoon ecu?
Old Jan 5, 2009 | 01:08 PM
mstewar's Avatar
maybe a JUN ecu?
Old Jan 5, 2009 | 01:26 PM
After doing some research the closest thing I can find to it is the hondata s300 series? with a custom build. Chip goes for 450-600 plus the hack. Very specific parts went into the build for a reason, I just dont know what everything was internally. Guess I will have to create another one or try an get a hold fo teh guy who built that motor I had.
thanks for the info.
jeck_bar2
Mar 11, 2009 09:12 AM
aggressivecivic
Mar 20, 2007 06:59 AM
kNOwLedGeDA9
Oct 5, 2005 07:03 PM
littlemracura
Aug 17, 2004 02:13 PM
MXPX
Jul 4, 2001 02:25 PM
