Piston rings shot!!!
Let me say first that I own a 00' Civic si and that I have a Greddy turbo set up on my B16. So my problem is that I have blown piston rings on my cylinder 2. I'm not completely sure if its my rings that are fried but i did do a compression test and cylinder 2 is low. Now I'm completely lost on what i should do to fix this. What is the procedure and what do I need to buy? Someone please help me and tell me what i need. Should I buy a hole new set of pistons and rings....
So this is my plans:
1.forged Je 9.01 pistons
2.forged eagle rods
3.arp head studs
4.acl rod bearings
Now before i do this i got questions:
When replacing bearings should i only replace rod bearing or is it necessary to also change out the main bearings?
What are the main bearings?
2.forged eagle rods
3.arp head studs
4.acl rod bearings
if you did a comp test and the cylinder was low, it could be the rings or valve seals
most likely the rings
on that car you would have to remove head and oil an
and tap the pistons up through the head
once off install new rings and push them back in with the ring compressor tool though
the pistons will be fine if your wanting to make more power and run more boost id go with new lower comp. pistons and rods but the b16 is not really a weak motor
thrust bearings sit on either side of the center crank cap. the grooved side facing outwards. as was said main bearings are just another term for crank bearings. you have 5 sets of them. make sure the bearings with the oil reliefs are on the right side (that would be block side, side with no oil relief goes in the crank cap). and match the bearing notches properly so they are touching when you place the caps in place. if you put them in wrong they will not bolt down properly. rod bearings don't have a top or bottom so you don't have to worry bout them. also just to be safe make sure you plastigage your main and rod journal clearances. i realize it will probably check out fine but its definitely something worth doing for that extra insurance that everything is in spec. be sure to hone out the cylinder walls as well, and you'll want the cross-hatching marks to be as close to 45 degree angles as possible. lastly this diagram will show you how to place the piston rings. i'd stay away from acl bearings. just use honda oem bearings, they're nitrite coated.
PINKFIFFTY
Jan 25, 2015 07:01 PM
Christopherian1982
13
Jan 18, 2009 02:15 PM
4EN[sic]
Aug 9, 2007 04:19 AM
