Suspension Tech sway bar
Old Aug 5, 2002 | 07:57 AM
yodude's Avatar
Default Suspension Tech sway bar
I'm trying to install the front anti-swaybar for 96-00 civic by sus tech I cannot seem to fit the "adaptor bracket" and the "end assembly" at the correct position on the control arm. Spacer on the adapter bracket is too big to allow it to slided down far enough toward the tire end of the control arm. the "end assy," which connects the bar and the bracket, is angled so far that I'm afraid it'll break. instrucitons say it should be close to 90 deg. any suggestions? Hope this makes sense thanks
Old Aug 5, 2002 | 08:39 AM
nixadm's Avatar
Default Re: Suspension Tech sway bar (yodude)
errm
pictures? I have a sway bar and it was a little rough getting on but not much
Old Aug 5, 2002 | 03:19 PM
yodude's Avatar
Default Re: Suspension Tech sway bar (nixadm)
Is there any way you can get the pic of your set up? then i'll probably know how to put it together. or alternatively, have you seen any pics on the web? thanks
Old Aug 6, 2002 | 03:31 PM
yodude's Avatar
i just spoke with the customer rep, and she suggested shaving a little bit off either the control arm or the spacer. any comments?
MechEng
Nov 30, 2010 03:30 PM
Rizzen
Oct 20, 2008 06:49 AM
trrbl1bmx
Suspension & Brakes
Jun 30, 2006 10:51 PM
mingbling96
Jun 21, 2005 02:41 PM
