Typical Map "/psi reading at Idle
Old Jan 1, 2009 | 11:53 AM
jaysalti's Avatar
Default Typical Map "/psi reading at Idle
What is the Typical Map ("/psi) range at Idle of approx 800 rpm for a stock GSR? Thanks in advance!
Old Jan 2, 2009 | 07:05 PM
fumatch's Avatar
Default Re: Typical Map "/psi reading at Idle
you should get 5 volts from pin d21 & d19
signal from d17 &d21. not running the standard MAP sensor should read 2.85V. if wiring is good. idle sould be .45V ----please correct me if im wrong----
Wire Sensor Code B Series
D21 A-GND Green/White
D17 B-MAP signal White
D19 c-5V Yellow/Red
Old Jan 3, 2009 | 03:55 PM
tech7427's Avatar
map and baro sensor with the engine off should read atmospheric pressure which is 2.85v , they should match with engine off, with engine runnning the map should be around a .5v at idle and baro sensor should read atmospheric pressure.
KURUPTinc
Mar 13, 2008 08:15 PM
Boostedb20EH2
Mar 5, 2007 06:41 PM
FERIOkid
Nov 11, 2006 04:07 PM
VTC_CiViC
Apr 12, 2004 06:00 AM
Ryanwb
Mar 31, 2003 03:41 PM
