1996 honda civi SI front end noise problem
Old Dec 31, 2008 | 11:05 PM
Integra4lyfe069's Avatar
Default 1996 honda civi SI front end noise problem
I replaced front wheel bearing and rear wheel bearing on driverside and did tire rotation and now im hearing like a wobbling noise/clanking noise when im just rolling . no noise wen accelerating, but when rolling i hear it lik the tire is wobbling but t isint, i raised the car it doesnt move. everythings tight?
I'm thing maybe ab ushing or something is gone ?
Help me please!
Old Dec 31, 2008 | 11:48 PM
98civdx's Avatar
Master Detailer
Default Re: 1996 honda civi SI front end noise problem
check an make sure you lugs are tourqed down to correct spec.
Old Jan 1, 2009 | 10:03 AM
the lug nuts r tight, hmm i dunno what else it culd be
Old Jan 1, 2009 | 11:29 AM
98civdx's Avatar
Master Detailer
sorry man
thats the only thing i could of think of
or maybe you didnt do something right?
go back through it.
Old Jan 1, 2009 | 01:16 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Maybe you pushed the brake dust shield into the rotor. If it's actually vibrating, maybe you seperated the axle while removing it from the hub.
Old Jan 1, 2009 | 01:25 PM
scottc76's Avatar
Maybe the tire is cupped?
wade's Avatar
Did not know Honda made a 1996 Honda Civic Si
Old Jan 1, 2009 | 01:27 PM
burningrex's Avatar
do you have a 2 piece rim...
Old Jan 1, 2009 | 01:44 PM
ifIexplode's Avatar
He's from canada, They're Si is our Civic EX.
Jack your car up, Put it in neutral and Spin the wheel, see if the noise appears.
Old Jan 1, 2009 | 02:45 PM
along time ago i did the front wheel ebaring like a month ago, it was fine.
two days ago i did the rear wheel bearing.
front has disc brakes and back has hub
i did tire rotation to at this time.
so after installing the rear wheel bearing and rotating the tire i notice ever since my front driver side is making a noise, soudns lik its a wobble noise something is loosing and wobbling and hitting.
I have a 1 peice rim and nothing recently was done to the front.
i jacked up car and trid to move the tire and it moves correctly, no shake or movement, so the wheel bearing is still fine. car was jus safetied too so the strus springs n contro larms r fine, i dont get it. maybe the rim is bad or something ? this makes n osense.
only thing i can think is the elbow bushing or something ? or axle?
but when im rolling it happens but accelerating it does, when i let out th clutch i hear a big paddle then i wobbles, but after its disengaged as well it stil ldoes it, nothing is wrong with the clutch either its fine. even sometimes when its in im changing n still movie the car still makes the sound. i seem to hear it mroe inside the car then out... wtf
enriquezf
Honda Civic (2006 - 2015)
Jan 16, 2019 05:48 PM
pityocamptes
Apr 13, 2016 03:25 PM
ITRBOY1433
Honda S2000
13
Nov 16, 2010 12:42 PM
JUNKIE DUCKY
16
Nov 2, 2008 10:06 AM
BigBadBuford
Jan 8, 2004 02:00 PM
