inline oil filters
Old Dec 29, 2008 | 08:57 AM
turbo-crx's Avatar
Default inline oil filters
where do you purchase these that have a -3 inlet and outlet? I can only find one's that have -4 inlet and outlet.
Old Dec 29, 2008 | 09:48 AM
Wanchai's Avatar
Default Re: inline oil filters
I was to looking for -an3 filter,but i´ve give up.
-an 3 to-an4 reducer is on the list now.
Old Dec 29, 2008 | 11:03 AM
HiProfile's Avatar
You could always tap into the oil system after the stock oil filter and save yourselves a headache. If the particles are enough to ruin your turbo, they are enough to ruin your motor. I've never seen a turbo die and the motor live (from particles in oil) when they used that setup.
If you are dead-set on getting that filter, you may have better luck with filters that have NPT fittings. NPT-to-AN fittings are easily found, as NPT is the standard for most presurized fluid systems.
kmaz93da
Jun 30, 2010 01:12 AM
Dubs13
Aug 1, 2009 07:22 PM
4Door Life
Apr 3, 2008 05:25 PM
alpha
Apr 18, 2006 10:13 AM
sslude
Feb 6, 2003 09:47 PM
