inline oil filters
You could always tap into the oil system after the stock oil filter and save yourselves a headache. If the particles are enough to ruin your turbo, they are enough to ruin your motor. I've never seen a turbo die and the motor live (from particles in oil) when they used that setup.
If you are dead-set on getting that filter, you may have better luck with filters that have NPT fittings. NPT-to-AN fittings are easily found, as NPT is the standard for most presurized fluid systems.
