fpr worth buying
so im about to boost my d-series motor and need a fpr and was wondering if this one would be worth buying?
http://cgi.ebay.com/ebaymotors/Fuel-...Q5fAccessories
You will need to tune your fuel pulse width via the ecu. Read http://www.phearable.net/tech/efibeginnerguide.html
no, that will not work because you will need to lower fuel pressure dramatically in order ot get the same amount of fuel volume, but even at that the injectors will have an inefficient spray pattern and will not atomize.
You do not need a fuel pressure regulator and the stock one will suffice and give you realibility much more then a cheaper fpr.
What you need to do is install the injectors and walbro 255 and have the car tuned. Basically during this event you will be telling the computer how much to pulse the injector to get the correct amount of fuel volume atomized into the chamber.
alright one more question i was told you could make the stock fpr ajustable is this true? like by drilling a hole in the top and puting a bolt it it with a nut.
"fpr worth buying"
no.
my friend bub put down 754 on stock fpr and stock fuel rail in his dd boosted gsr hatch. insane, i know. just goes to show you how good some stock parts hold up. but thats bseries.
no.
thats the B&M FPR, you mod. your stock one. You really dont need to do anything with it, it works fine to over 400hp with no needs of modding it. its more of a look at me thing under the hood than a functional piece
Originally Posted by Hiii Im TYLER
gee... I don't ever remember bub making 754whp. Maybe 730tops, but @ RRev 680. I don't know how many times we have to correct you kid. Get your facts right.
Originally Posted by gringotegra
x2
edit: he made around 730.
I use to kick it with bub way way way way way back in the day
before he was into hondas matter fact i got a picture of bub and tj dressed up
as girls lol
