Is there a shortcut for wiring up knock sensor????
Old Dec 19, 2008 | 01:48 PM
mustninty20's Avatar
Default Is there a shortcut for wiring up knock sensor????
I swapped an OBD1 GSR into a 93 coupe with the stock EX harness, stock GSR ECU and basically I was wondering if there is a shortcut to get rid of the knock sensor CEL besides wiring it up. I know the sensor is useless, I'm just trying to get the CEL out so I don't fail inspection.
Old Dec 19, 2008 | 02:01 PM
94EG8's Avatar
Seagull Management
get the ECU chipped and disable the knock sensor. If you have the sensor it's cheaper to just run the wire, its only 1 wire.
Old Dec 19, 2008 | 02:25 PM
Ya I guess I'm lazy, haha. I figured if there was an easier way I would have found it some where online. And actually since I'm pretty sure I will be taking the wiring up route, do I have to cut a plug off a harness and wire up D3 and ground? I have not done it before.
Old Dec 19, 2008 | 03:20 PM
ifIexplode's Avatar
Alot of people will say you need a sheilded wire for the knock sensor.
I myself have never used one and never had a problem.
Other people say the sensor grounds itself on the block.
The knock sensor is a comman honda connector.
Get a two pin connector and ground the one if you want. I depined the one wire and never had a CEL or any problems.
I believe its the same plug as the VTEC pressure switch.
Or its the solenoid, I forget.
But seriously, You can wire that up in like 10 minutes.
Old Dec 19, 2008 | 03:36 PM
iamthefollower's Avatar
Do you have emissions? If you do I know my friend down in Atlanta where they have emissions failed for not having it wired up.. but like 94EG8 said, you can have the ecu chipped and have the knock sensor disabled from it.
eskerley
Dec 4, 2007 08:18 PM
s_vares
Sep 3, 2006 02:54 PM
Anova
Jul 6, 2005 06:31 PM
ddong2lee
Mar 4, 2004 05:06 AM
