non vtec ecu with vtec engine?!?!?!
Hey whats going on. I have a D15b7 with a d16z6 head im about to put on. i have everything but the vtec ecu, looking to get a p28 ecu. Anyways i need to know if you can use a non vtec ecu on a vtec engine for a while. its only temporary till i get more money for the ecu. any help, ideas, etc would be great. thanks
the maps at all rpm are differant because of the size intake/exhaust ports the compression ratio, manifold design and 100 other things.
I ran a P2E ECU on my y8 motor for like a month. It threw a code for too lean. And was also in limp mode for some reason.
So, You can do it. probably wont hurt anything substantially, But i wouldnt do it forever.
ya when I bought my car it had a P2E on it (97 EX). I didnt realize it for a month or so since this was my first honda i wasnt exactly sure wtf was wrong with it. Just that it was way too slow lol. So yes it will work, but u wont get great gas mileage and it will run like crap.
i have a vtec ecu with a non vtec motor mine runs fine has idle roll if you try to kick vtec in tho. i dont think you should run a vtec ecu with a non vtec engine tho.... cant be good
i have a p28 ecu i might let go of for the right price
when i bought my 94 ex it had a z6 with a p06.
i drove it that for a few months (drove fine but no vtec, even over 6000+rpm), then modded the p06 for vtec.
since then i have gotten 2 p28's and 2 more p06's.
they all have same circuit board, 1720, and the same components except the p06's didn't have the vtec components.
there maybe other boards in a p06 but all of mine have 1720s.
cliff notes:
answer to OP's question, YES if its a p06
p28 = p06 w/vtec components
cliff notes:
I have the same setup on my 93 civic and with the stock po6 non vtec it ran fine. But when I got the chipped po6 and connected the vtec it was a whole new world So drive it it will be ok or at least mine did fine.
blacktibby07
Jun 8, 2011 07:11 AM
