92 civic vx ecu
Old Dec 18, 2008 | 01:45 PM
integra_speed's Avatar
Default 92 civic vx ecu
i got a 92 vx and for some odd reason they put in a p28. lmao. theres some kinda vtec but its pretty funny. the rpm climb super slow even in 1st and when i hit like 5500 or somthign a instant burst of... i wouldnt say speed but the rpm jumps. but for sure its not running right. is this just the ecu? has anyone else tried a p28 on a vx motor? what ecu goes with the vx?
btw i bought this for $850 from some mexicans. haha
Old Dec 18, 2008 | 02:04 PM
turboteg90's Avatar
pm for noodz
you need the p07 ecu witch i have,pm if you want it
Old Dec 18, 2008 | 03:14 PM
whats making the p28 not work with the vx motor?
Old Dec 18, 2008 | 06:15 PM
94EG8's Avatar
Seagull Management
Its just plain not the right ECU, fuel and timing maps are different, the D15Z1 in the VX is a Vtec-e engine, its not normal vtec and its designed for fuel economy. The P07 is also setup to use a 5 wire wideband O2 sensor and an EGR valve.
Old Dec 18, 2008 | 06:19 PM
freakasis's Avatar
does the engine clock say d15z1? if it does and the head is a z1 head, then yes you need to change the ecu. and ont get on it or rev it out until you. it will break your motor!
jdmhonda25
Jan 3, 2014 09:53 AM
JDM96SpecCTR
Dec 25, 2004 08:57 AM
Import13alla
May 28, 2004 06:37 AM
Desperado
Apr 15, 2003 12:51 PM
FLCivic
Jan 8, 2002 04:14 PM
