shut off switch???
Old Dec 15, 2008 | 05:24 PM
corcoranb20's Avatar
Default shut off switch???
i hear there is a switch are something of that kind on a 88 91 crx that will not let u get spark is this true are false ?? and if ture where at
Old Dec 15, 2008 | 05:32 PM
acmoc's Avatar
you can do allot, I have two, ignition and fuel. The fuel one is in the faq
Old Dec 15, 2008 | 10:05 PM
dacrxguy's Avatar
cut your ignitor wire youl get no spark trust me. there is also one for the fuel pump but people can trace it unless you hide it real well https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-91-crx-ef-civic-frequently-asked-questions-faqs-1508680/ is the faq alot of info can be found there and here is the thread https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/faq-diy-how-fuel-pump-cut-off-switch-1297327/ but like my teacher always tells me when i talk about alarms/security if they want your car they'll bring a tow-truck
Old Dec 15, 2008 | 11:06 PM
Tyson's Avatar
not from the factory. there is no built in switch.
ppl install security switches that do this tho. its not hard. its what theyre talking about.
fords are known to have an automatic fuel cut off switch in case of an accident or tow or something. you need to manually reset it from the inside the trunk. that sucked finding that out the hard way when i had a mercury topaz as the family car.
Old Dec 16, 2008 | 01:42 PM
dacrxguy's Avatar
did you run into a pothole and set off the switch?
Old Dec 16, 2008 | 01:56 PM
Tyson's Avatar
had it towed after a flat tire. and could never get it started again...
until someone pointed out the switch, after replacing the ignitor and starter relay and whatnot.
Old Dec 16, 2008 | 02:45 PM
dacrxguy's Avatar
yeah my family member hit a pothole doing 65 on the freeway and that set it off they called a tow truck guy and he just facepalmed.jpg because he knew what had happened i think there called inertia switches
Old Dec 16, 2008 | 07:23 PM
acmoc's Avatar
Do Hondas have these? We might already have a built in kill switch
Old Dec 16, 2008 | 09:05 PM
dacrxguy's Avatar
no older Hondas do not have these only some gm's i think newer cars have a more advance system that relies on sensor used with the srs system
Old Dec 16, 2008 | 09:22 PM
acmoc's Avatar
my brothers old ford had something like this to open the door
attemptmischief
Jul 23, 2013 03:01 PM
melloman
Feb 14, 2012 03:41 PM
hatchinprogress
19
Jul 22, 2004 10:35 AM
LoooseGSR
Audio / Security / Video
May 29, 2003 12:39 AM
96tegsr
Feb 6, 2003 08:01 AM
