fuel kill switch
Old Feb 6, 2003 | 04:57 AM
96tegsr's Avatar
Default fuel kill switch
Can anyone post the steps on DIY fuel kill switch. I dont want my car gettin stolen. Any suggestions where to put the switch in the car? TIA
Old Feb 6, 2003 | 05:10 AM
Eva01's Avatar
Default Re: fuel kill switch (96tegsr)
Try doing a search of "fuel Kill" or "fuel switch". Here a thread or two to get you started.
https://honda-tech.com/zerothread?id=187410
https://honda-tech.com/zerothread?id=389627
Old Feb 6, 2003 | 05:27 AM
CTR94Joes's Avatar
Default Re: fuel kill switch (Eva01)
Ok if the instructions sound vague i'm sorry.
Find the wire going into your fuel pump (fuel pump
is located under your rear seat in the middle) you'll
see the wires coming from it and you basically tap into
the wire using whatever you feel like ie. splice it
or audio wire connector and run a wire to the switch
which is gonna be hidden. Thats pretty much it.
With the switch off the fuel pump will be off which
doesn't give it any fuel. So you'll have to switch it on
everytime you wanna drive. Ok thats about it. I'll
let you guys know which wire to tap into when I
actually do it. email or IM me if anything comes
up.
UPDATE: THe wire you cut is the yellow/green wire
(the thickest of the two)
Old Feb 6, 2003 | 06:17 AM
Ronin Integra8's Avatar
i'm not sure, but doesnt the first thread state not to cut the ground wire, while the second tells you to cut the ground and do the switch through the ground???
i'm curious on how to do this also. I'm gona do this when it gets a lil warmer out.
Old Feb 6, 2003 | 07:03 AM
fivespeedintegra's Avatar
Default Re: fuel kill switch (Ronin Integra8)
either method should work...cutting the ground may be safer as you are not dealing with a live wire
Old Feb 6, 2003 | 07:56 AM
cheezthis's Avatar
Default Re: fuel kill switch (fivespeedintegra)
I know I've answered this more than once on here...so try a search.
Tekken had some great ideas for this a few months back too in the audio/security forum.
I suggest using a relay instead of just a switch. You don't have to, but it's safer.
Old Feb 6, 2003 | 08:01 AM
thaiphob's Avatar
Nikon!!!
when i made my kill switch, i just snipped the grounds and installed a switch. the hard part is finding a hidden location where to put the switch.
beastman@
Audio / Security / Video
May 17, 2008 01:05 AM
96electronH
Dec 2, 2007 05:29 PM
99fbpem1
Aug 19, 2007 04:23 PM
tegasaurus
Dec 12, 2002 02:54 AM
96GSR
Apr 26, 2002 12:38 PM
