b18b into 1995 civic ex(vtec) question...help!
Old Dec 14, 2008 | 05:51 PM
rhdekhatchie's Avatar
Default b18b into 1995 civic ex(vtec) question...help!
im sure there is a post somewhere on the swap and things needed but my question i cant seem to find a answer for....this is it i have a full usdm b18b with all parts from my dc2 that im working on right now and motor is just sitting, now i have found a 95 civic ex shell for sale....my 1st question is i want to keep it obd 2 can i use all parts from motor ex: motor mounts, b18b engine harness, axles, shift linkage nowmy concern is when it comes to the plugging up of the engine harness to the civics wiring....can i just plug the harness to the shock tower plugs and then plug in the obd2 ecu? that my only thing is if i can plug the engine harness to the civics wiring and if i can plug my obd2 ecu or do i have to purchase a obd1 to obd2 jumper harness?
Old Dec 14, 2008 | 06:23 PM
Search-first's Avatar
don't go obd2, waste of time. Get an obd1 Ls ecu off of ebay for like $40 or something. It'll save you a little headache. Won't have to worry about wiring up the CKF sensor, or secondary O2 sensor. But since the plugs on the injectors,distributor, and alternator are different, it would benefit you to use the integra engine harness.
Old Dec 14, 2008 | 06:34 PM
Ya Digg's Avatar
I think he has to have a matching ECU since he is in California.
Old Dec 14, 2008 | 06:50 PM
eg_boi's Avatar
if it's complete swap it will swap over with no problem using the integra harness. everything is plug and play.
if you want to run an obd1 harness then you would need to source a obd 1 dizzy, alternator, and injectors or rewire them into your harness.
Old Dec 14, 2008 | 07:01 PM
yeah thats my concern since i have a complete ls swap and i mean everything form my integra i want to make sure it has the right ecu for it, so if i drop motor in with all parts i plug up engine harness and the obd2 ecu is there anything additional i have to wire up or no?
Old Dec 14, 2008 | 07:05 PM
why would i haev to wire up anything if im using the obd2 b18b with obd2 componets with b18b engine harness? the ckf sensor would just plug into the engine harness form the integra right and the secondary o2 sensor would be my next question how would i wire that up being that the plug for that is in my integra cabin harness?
j4s0n1337
19
Jul 21, 2019 06:47 PM
appelsos
11
Jul 11, 2011 06:24 PM
Pete_SI
11
Apr 14, 2007 12:00 AM
pine_apple45
11
Mar 20, 2007 08:12 PM
Cristorey34
Aug 6, 2005 07:36 AM
