Rough Idle
Old Dec 14, 2008 | 01:34 PM
RudeLudeHatch's Avatar
Default Rough Idle
Heres a simple question for you huys cause im stumped. Have a h22 in my eg and it idles up in down like i had a iacv problem. Iacv is fine i think its the tps because i have no vacum leaks and when i take my intake off and stick my finger in the hole for the tps it idles smooth. Its a stock TB and the tps has never been changed. Im not throwing any codes. What do you guys think.
Old Dec 14, 2008 | 01:38 PM
cehcivic15's Avatar
check the fitv
Old Dec 14, 2008 | 01:52 PM
So since the tps vac port is sucking like a hoover i could be the fast idle. Isnt there a way to block that of. Whats the pros and cons by doing that.
Old Dec 14, 2008 | 01:55 PM
sorry meant the fast idle port is sucking way to much air my bad. What do i do to fix this
Old Dec 14, 2008 | 06:47 PM
Ok i was having the bouncy idle from iacv.When i stuck my finger in the port hole on the throttle body the motor idled perfect. So i took some honda bond and some aluminum and blocked off the iacv. Do i have to reroute the coolant lines or can i leave them like they are. Funny thing is now after blocked off if i remove the sensor it surges like it normally would if oem. Just got this hatch wonder if the ecu is chipped cause im not running a resistor box for the injectors either.
1991civicb16
Jul 16, 2011 12:38 AM
killa_lude
Jul 17, 2004 08:39 AM
egizzle8
10
Feb 9, 2004 04:25 AM
OneFastGsr
Oct 8, 2003 08:30 AM
TurboCRVTEC
Oct 9, 2002 05:38 AM
