98 piston ring replacement
Old Dec 13, 2008 | 08:47 AM
alexb18c1's Avatar
Default 98 piston ring replacement
Any one have any info on replacing piston rings, on a 98 prelude. I heard that you can't just replace the piston rings with out having to take the engine out and send it to the machinist. Is it just possible to replace the rings with just new ones.
Old Dec 14, 2008 | 07:48 AM
preludin's Avatar
If ur mechanic is familiar with the hseries engine he should able to reccomend. But yes u can replace rings without removing the entire motor. Seen it done before. But why just replace rings? How many miles do u have, and are you haveing more then normal oil consumption?
Old Dec 14, 2008 | 09:37 AM
vinuneuro's Avatar
If you think you need new rings, you at minimum need to have someone check the bores for roundness and taper. The specs are in the helms.
http://www.spoonhonda.com/Free_Downl...uals_s/119.htm
Old Dec 14, 2008 | 01:04 PM
alexb18c1's Avatar
I'm consuming oil more than normal but when I take off I see some blue smoke, wich I'm assuming my rings are bad. Also the compression on pistons 12&3 is 180psi and #4 is 190psi. thanks for the replies.
Old Dec 15, 2008 | 07:33 PM
Crash_Control's Avatar
Those compressions aren't very far apart now was the engine warm when you took these readings ?
You need to do a wet and dry compression test then compare the two.
If your compression jumps up allot then you have a ring issue if there is little or no change the problem is in the valves.
Although 180 to 190 psi is a good value so i would suspect a valve stem seal issue.
Old Dec 16, 2008 | 04:59 PM
alexb18c1's Avatar
I did the test while cold. A wet test? you mean put some oil in the cylinder and test the compression. Never done that. thanks for the input
Old Dec 16, 2008 | 05:11 PM
vinuneuro's Avatar
If you see smoke after idling for a little while and then take off, that's a sign that your valve seals are bad.
Old Dec 17, 2008 | 06:03 AM
Redprelude98's Avatar
i hate to jump in on your thread but mine doesnt do it whenever i at idling and then take off, it really only does it whenever i get into vtec or high rpms? is this the same thing with the valve seals or will this be the rings?
Old Dec 19, 2008 | 05:58 PM
You still have to do dry and wet compression tests with the engine warm to find out.
Old Dec 19, 2008 | 06:23 PM
alexb18c1's Avatar
I'm going to try the compression test again see what results I get this time I will post the results
a1320honda
Jan 10, 2008 05:18 PM
h22aBB4
Dec 26, 2006 02:43 AM
Aeka GSR
Sep 28, 2003 11:15 AM
non-VTEC
Oct 26, 2002 08:15 AM
Islander
Oct 11, 2002 02:45 AM
