Driver side headlight not working (retrofit)
No need to mention the full setup, but I have a Hella / Philips Gen 3 HID kit with a CustomLightz harness.
The driver side headlight stopped working, and I already know that it's not the bulb.
So it's now either the ballast, harness (fuse), or ground, correct?
Could a bad ground on one side of the engine bay for the harness cause that side to stop working?
Thanks.
Thanks.
Didn't flicker at all.
It was raining like crazy last night when I was driving home from school. I noticed the headlight was out once I pulled into the driveway.
I'll be swapping the ballasts in the morning.
So you're sure the ballast is the problem?
I had a poor ground on my driver side relay when I re-made custom harnesses for my retrofit back in 2004, which caused my left side headlight to not work. I moved the wire to a better/tighter ground and it's worked fine every day ever since then.
Bleakened
Oct 17, 2016 07:41 AM
