Rear Brake Question
Hi,
My passenger side rear brake caliper is all rusted then the same side the e-brake is not working coz the spring that holds the cable is stuck because of the rust.
Now I know the the brake still work but not the e-brake, can I replace just the spring without replacing the the whole caliper or this is part of the whole caliper and I need to replace all.
Thanks
Thanks
The whole caliper, unfortunately.
The adjuster mechanism on the '95 Accord rear caliper utilizes a threaded piston and a threaded bolt as part of the application mechanism and your's is most likely rusted Solid. Refer:
http://www.hondaautomotiveparts.com/...+BRAKE+%281%29
You do have cheaper options than Honda (However). You can find both reman and OEM grade replacement assemblies from aftermarket sourses which will soften the financial blow (somewhat)
P
P
miksew
Oct 7, 2006 11:46 PM
PhatBoy5015
Jan 9, 2006 09:45 AM
Vinceg99
Nov 21, 2002 05:42 AM
