Oil pan and Drag Kit questions....
Old Aug 2, 2002 | 05:25 PM
AllMotorITR's Avatar
New User
Default Oil pan and Drag Kit questions....
is the Drag 3 kit straight bolt on to the Type R or do I need to shave the block, etc? Also, where can I get a moroso oil pan? I don't want to weld to my stock pan, and then run into problems if I have to take the turbo off...
Thanks In Advance,
Chris
Old Aug 2, 2002 | 05:27 PM
DragII's Avatar
25 Year Member
Default Re: Oil pan and Drag Kit questions.... (1 FAST R)
buy a cap for the fitting you weld on the pan...problem solved.
DRAG is Not really a bolt on...you will have to do bunches of minor mods to get it in right. search...
Old Aug 2, 2002 | 05:33 PM
Etylorcen's Avatar
Default Re: Oil pan and Drag Kit questions.... (DragII-Sellout)
The block shaving is very easy and doesnt take long. Like he said just get a cap when you have to take hte turbo off. When I removed my turbo for smog I just capped the return and the oil feed line and that was it. You can get a moroso anywhere. http://www.importparts.com, summit, jegs, Just shop around.
Old Aug 3, 2002 | 03:05 PM
turbo Si's Avatar
Default Re: Oil pan and Drag Kit questions.... (Etylorcen)
I just bought a bolt with an AN thread, welded it in and ran a steel braided line. A 90 degree fitting from the turbo and a 45 degree fitting from the oil pan. That setup seemed to work best for proper drainage.
Old Aug 3, 2002 | 03:27 PM
PrecisionH23a's Avatar
Here are some pictures of the modification we did to a b18c5 block to install the drag turbo kit...
Old Aug 3, 2002 | 08:00 PM
Ivan's Avatar
senior gold member
Default Re: Oil pan and Drag Kit questions.... (GudeH23a)
what did you use to cut the block?
Old Aug 3, 2002 | 09:23 PM
Cwest EK's Avatar
Default Re: Oil pan and Drag Kit questions.... (Ivan)
i used a dremel to cut mines...few cut-off wheels later the turbo fit fine. I also agree just to run a cap to the oil return fitting on your oil pan when removing the turbo.
toolowsol
Feb 9, 2006 01:52 PM
rudebwoy
May 21, 2005 12:28 PM
...emu...
Jul 22, 2004 07:17 AM
orange.honda
May 6, 2003 04:14 AM
Teg4e
Jun 20, 2002 08:34 PM
